Quantcast ;) I found my own - Page 6 - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1966-1977 Ford Bronco
  #51
Old August 18th, 2012, 12:52 PM
Whats the best method for engine management with the 91 bronco 302, mated to the 435/205? I want to use the original gauges if possible. But do want to keep the work on the dash to a minimum.
Budget friendly ideas?
  #52
Old August 18th, 2012, 01:49 PM
Stock computer that was for a 5 speed.It'd actually be pretty easy. The Speedo is cable driven, so it's not even involved in the engine management. Tach is fed of the negative side of the coil like usual, etc.
  #53
Old August 18th, 2012, 03:01 PM
What booba said. The wiring harness from the any 97-91 302 five speed would work perfect to run the engine and the gauges are very simple so you could rewire if need be.
« General 1966-1977 Bronco information | There is no next thread »
(View-All Members who have read this thread : 78
975.4 , AlfredHof , ArnoldKam , ASwaff400 , BigBlue79 , BigRob , BigTrouble , bikertrash3531 , Billygenna , Booba5185 , Clydetaw , CrazyD , CrisMcCon , DarrellUnsob , DavidFloca , DavidPramp , DIXIE FIX , Donaldjen , DoubleDee , F150GT , fairyfub , Firedog67 , Franciswem , GeorgeEtela , harrison28 , Harveypevduc , HawaiianF150 , Heatherageda , her , herbz , jallen3521 , Jamesbinty , Jerometox , Jesseplosy , JSoko , KelvinPriow , Klitch , Lostin90s , MariaFaf , marmaduke , Michaelanify , michaelsnodgrass18 , MonikaHycle , nine5flareside , ONELOWF , pete59edsel , Purintto , Raleigh , RalphDiz , Red91 , RenatoVoics , Ridgerunner , Robertcem , RobertEmavy , RobertSnubs , RobertVog , RobertVoT , Rodneyvat , rtdidaho , Russo2 , sbellinghausen , Schumi112 , Scotyroone , screwon23s , skatebowd , sochi.cat/vek , Soxfan68 , Stewy 39 , Svetlanabike , TimothyNut , Tr00b , Tylewulxwxwe , Wes , Wheelsblank27 , whitesleeper , Williamidons , XRumerTest , Yankee
I found it fsawer New Member Introductions 3 January 25th, 2011 09:10 PM
Look what I found! Part 2. SS FatMan Ford SVT Raptor 15 January 6th, 2010 06:10 PM
Look what I found! SS FatMan Ford SVT Raptor 7 December 25th, 2009 10:04 PM
Look what I found at my dealer! RedHot150 Ford SVT Raptor 21 October 30th, 2009 08:27 AM
found
