Quantcast 2001 F150 Supercrew horn problem - Ford Truck Club Forum
Ford Truck Club Forum > FORD F-100 | F-150 SERIES > 1997-2003 Ford F150
Old March 8th, 2018, 07:20 PM
oldpops's Avatar
oldpops oldpops is offline
Default 2001 F150 Supercrew horn problem
Hi all. We have a 2001 F150 Supercrew (5.4L, automatic, 2 wheel drive) and the horn has been out for a few months. The only thing I can think of is that a few months ago we had a lot rain and thanks to the leaky 3rd brake lite, we got moisture into the cabin. The inside of the windshield would have condensation on it and we got a musty smell inside so we did our best to seal around the light. Not sure if it is related but a short time after that we noticed that the horn didn't work. The doesn't work with the key in the ignition or not, and doesn't work whether we push on the steering wheel horn, or whether we push the lock/unlock button on the key FOB. Finally got some time off during the day to do some troubleshooting. First thing I checked is the fuse, which was bad. Replaced the fuse and now we get a muffled sound, not the beep of a horn. Just to be sure we swapped the horn relay and got the same results. My guess is the horn must be the problem but since I believe this model has both a low and high tone horn, I'm trying to figure out why both horns would go bad? Any suggestions?
Old February 15th, 2019, 11:47 AM
lilyblake102's Avatar
lilyblake102 lilyblake102 is offline
u might want to check your terminals they might be loose or the wires are bad
(View-All Members who have read this thread : 47
AlfredHof , Billygenna , Carlosjekly , Danielfuh , DarioNeelp , DeweyFum , DonaldGOR , DonaldVaf , DonaldWoche , EmmittImmap , FrankCoosy , GeorgeEtela , glc , harrison28 , Heatherageda , JeffreyKeX , Jendiump , Jerometox , Jesseplosy , KaryCef , KeithFoult , KevinDuels , LeslieDruby , lilyblake102 , LuxuryBetvewly , Martynaw , MichaelDug , Normandanoro , oldpops , PatrickNob , Purintto , RalphDiz , Ramonvog , RicardoMit , RobertEmavy , Robertnut , RobertVog , RobertVoT , Rodneyvat , RonaldFon , Ronnietah , Russellasymn , SemmionsCom , Shanehib , sochi.cat/vek , Stevenspolf , XRumerTest
2001 Ford F150 SuperCrew 5.4 TCFord 1997-2003 Ford F150
1 October 29th, 2017 07:43 PM
2 questions on 2001 F150 Supercrew oldpops 1997-2003 Ford F150
1 July 6th, 2017 09:42 PM
Hey new here in orlando F150 Supercrew off road 2001 FordSupercrewOrlando New Member Introductions 7 May 7th, 2013 10:32 PM
sub for supercrew f150 01f1502wd Stereo | Electronics For Sale
1 May 1st, 2011 08:13 PM
3V vs 2V in f150 (supercrew) vGnzlz 2009-2014 Ford F150
32 January 10th, 2011 01:42 AM
2001 , f150 , horn , problem , supercrew
