Quantcast Draining gas without dropping tank??? - Ford Truck Club Forum
Old October 28th, 2012, 02:19 PM
adoporto's Avatar
adoporto adoporto is offline
Default Draining gas without dropping tank???
So before I started my motor swap. My truck sat for a long time.....yes I know what was I thinking! 2 yrs....I don't have much in the front tank showing its on Empty. The 2nd tank I will never know gauge is out. I was wondering if there is a way to drain tank without dropping it.
I am going to change out fuel filter already have it off. I am in process of putting everything back together. Motor is bolted in and exhaust is also hooked up, the only thing is getting front end in and hooking up lights and battery. Once I do this can I just turn key off and on till no more is coming out??? Or is there an easier way or no other way to do this but dropping tank. Gas smells like varnish....heard that is not good.
Old October 28th, 2012, 02:37 PM
varnish smell is a bad sign
Drop the tanks and have them flushed , No other way than to drop them and the varnish smell is a bad sign of contaminants sticking to the bottom, sides and top of the tank
this must be removed or you'll suffer with fuel filted blockage and possible trash in the injectors or carb
then flush your fuel lines
90f150xltcenturion , adoporto , Booba5185 , chesster51 , consortcummins , HawaiianF150 , JSoko , KC9RFO , KD-DET , rikard , Russo2
Voltage Dropping Red91 1973-1991 Ford F150
12 June 5th, 2012 08:37 PM
Front Tank issues tity04 1992-1996 Ford F150
15 December 4th, 2011 09:48 PM
Rat Roaster - Blending The Gas Tank [S2 Ep.3-3] Gearz Gearz 0 February 3rd, 2011 04:40 PM
Dropping the back end?? Fordduckhunter2 1997-2003 Ford F150
20 September 12th, 2010 09:50 PM
Truck Tank or Tank Truck JSoko General Discussion
3 March 3rd, 2010 03:49 PM
draining , dropping , gas , tank
