Quantcast Oil pan question - Ford Truck Club Forum
Old March 2nd, 2015, 09:26 PM
chesster51's Avatar
chesster51 chesster51 is offline
Default Oil pan question
Mine is leaking and I'd like to change the gasket. Looking at my chiltons manual it lists draining coolant, removing upper intake manifold, exhaust and transmission crossmember. I know the mounts will have to be unbolted and motor raised some, but is it necessary to remove all that other stuff to remove the pan?
__________________
Old March 3rd, 2015, 07:14 PM
ncranchero's Avatar
ncranchero ncranchero is offline
Liked 4 Times in 4 Posts
Never done that one so I cannot offer any advise.
Steve
1994 F150 4x4 SWB 4.9L M5OD 3.55LS
2002 Escape 4x2 3.0L Duratec
2014 Transit Connect 2.5L
Old March 3rd, 2015, 08:45 PM
chesster51's Avatar
yea, I think I'm going to try and do it by just unbolting the exhaust at the manifold, taking the bolts out of the motor and trans mounts and jacking the motor up enough to get clearance.
Old March 3rd, 2015, 09:29 PM
go slowly and keep an eye on things as you raise the engine, watch the firewall also
keep in mind that a lot of the crank and mains are below the level of the gasket
Old March 4th, 2015, 02:13 PM
are you gonna use an engine hoist? or try to jack it up from underneath? I believe they suggest removing the intake manifold to allow for your chains to attach to the motor eyes without any pressure against the plenum. when I removed the motor from my 88 f150, I didn't take the plenum off,....the chain had a lot of pressure along the side of it.
Old March 4th, 2015, 04:42 PM
not sure about your year but 302 heads have bolt holes in the front and rear
I use a chain from the rear of one head to the front of the other
Old March 4th, 2015, 10:22 PM
chesster51's Avatar
I'll be jacking it up from underneath with a block of wood on the jack.
Old March 5th, 2015, 09:12 AM
what will the block of wood be pushing against ?
also check your engine mounts while you got it up, as well as the one for the trans on that crossmember
they'er not that expensive, and would be easy to replace while you got it up
Old March 5th, 2015, 06:28 PM
chesster51's Avatar
Just replaced all three mounts about two weeks ago. I plan on using a piece of 2 x 4 long enough to span the width of the oil pan and raise it there. The main pressure will be on the vertical sides of the oil pan. Did it this way to replace the motor mounts with no issue. I'm hoping to raise it and shim it up with wood under the mounts so the jack can be removed.
Adsquared , ASwaff400 , chesster51 , cobra1 , dkenny9 , glc , harrison28 , Hoosier , JSoko , KC9RFO , Lostin90s , ncranchero , Ozzie , Russo2 , skatebowd , The Frankster
DEF question MR_Pete 2011-2016 Ford F250 | F350
10 November 27th, 2018 06:49 PM
Question 54bgger FTC Media Center
5 December 29th, 2012 03:13 PM
question grayson2121 1997-2003 Ford F150
4 October 27th, 2012 11:06 AM
s.a.s. question BigTrouble 1992-1996 Ford F150
3 September 21st, 2011 11:36 PM
LED Question MR_Pete 2004-2008 Ford F150
7 December 16th, 2010 08:16 PM
oil , pan , question
