Quantcast Windshield wiper motor remove and replace - Ford Truck Club Forum
Old August 21st, 2009, 02:13 AM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 258
Arrow Windshield wiper motor remove and replace
A common issue with tenth gen f150’s is for the windshield wiper transmission to come apart like so:
To remove and replace this assembly, start with the wipers. Pry off the caps over the wiper arm nuts. Once you have the caps off, a 15mm socket will remove the nuts. A couple of taps with a light hammer will break the wiper arms loose from the splines. There are 7 or 8 philips head screws across the top of the cowl. (you may want to remove the radio antenna for easier access to the screws on the passenger side.) Once those are removed, open the hood and remove the clips.
Next grab one end of the rubber weather strip and pull up and across to remove this. Now you should be able to remove both halves of the cowl. Once the cowl is out of the way, unplug the wiper motor and remove the three 8mm bolts. Next comes the tricky part. Working from the drivers side, push the assembly towards the passenger side and work it into the well area below the transmission assembly. Now pull back towards the drivers side until the far end drops into the well. Work back and twist the wiper motor towards the front of the truck, while lifting up on the end nearest you and carefully work the assembly out of the well area.
After you have removed the assembly, you can turn over and remove the four bolts (8mm) and separate the motor from the transmission assembly. Bolt the wiper motor to the new wiper transmission assembly and re-assemble in reverse order from above.
Now, I tried to ‘fix’ the joint by stuffing a grease covered piece of sock in between the plastic cap and ball joint, but it came apart after half a swipe.
This assembly is not available as an after-market part (yet) and buying it from the stealership will cost you around $125 (without the wiper motor). If you decide to go the wrecking yard route, make sure you check for play or release on the replacement part. Obviously this procedure is the same for wiper motor replacement.
Big T
Old September 2nd, 2009, 12:51 AM
I hear if you drive fast enough in the rain you dont need wipers. Then again, I am the who trys to play dodge ball with the rain drops.
Anyone seen my special helmet?
Old September 2nd, 2009, 01:16 AM
Add a little of that Rain-X or whatever they call it and yoU don't have to go as fast!
Or tie some rope to each side of the wipers and rUn it throUgh each side window - then pUll one way then the other!
BATES
Banks & PHP Powered
Old September 2nd, 2009, 01:39 AM
BigT67's Avatar
Images: 258
I broke down and bought the new assembly from the Ford parts counter and did the whole remove and re-assemble again (Grrrr) and now the effin wipers are backwards! They stop in the up position. Somehow during the re-assembly the motor got out of sync and I just haven't had the time to take it apart a third time (kitchen plumbing decided to come apart and ruined the floor of the cabinet). Plus the salmon are beginning to show up in area rivers!
Big T
Old September 4th, 2009, 12:57 AM
Rope !! Open Window !! Sounds like hunting season started!!!
Honey - Hold this while a drive through them ruts!! Dun letgo or you walken!!!!
Old September 4th, 2009, 01:03 AM
i wonder if you thread the bolts on backwards and from the backside - will the wipers stop in the down position? It worked for this guy
Just kidding with ya. that kinda sux the back side of a screaming eagle. all that work. ah well just tell people you did it on purpose to get a response and hand them a this sign
Old September 4th, 2009, 01:07 AM
BigT67's Avatar
Images: 258
Roger that! custom wipers mod!
Big T
birchbay , DoubleDee , ewalton9 , gleitzaj24 , JeremiahM , jymk1 , Schumi112 , timroach19
Anyone ever remove their smog pump? nine5flareside 1992-1996 Ford F150
5 October 8th, 2010 11:00 AM
MMMM... New Windshield Agjake11 1997-2003 Ford F150
15 May 21st, 2010 09:17 PM
Weird Wiper Problem (2008) TedC 2004-2008 Ford F150
9 February 12th, 2010 09:53 AM
Remove stuck rotor JSoko Garage Talk: Shop Class 101 2 December 16th, 2009 07:03 PM
Replace brakes JSoko Garage Talk: Brakes & Suspension 0 December 16th, 2009 09:06 AM
motor , remove , replace , windshield , wiper
Powered by vBulletin® Version 3.8.6 Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
