Quantcast Front Brake Rotor Gouged - Ford Truck Club Forum
Old May 31st, 2017, 03:52 PM
CMelder's Avatar
CMelder CMelder is offline
Exclamation Front Brake Rotor Gouged
Howdy All,
Wanted to check to see if any of you have had an issue with one (or more) of the brake rotors becoming gouged and torn up in a relatively short period? My 2014 F350 has 65k miles on it and I recently heard the grinding noise, I couldn't stop at the time and check it then. This morning I noticed more than the normal amount of brake dust on the front left wheel, so I looked at the rotor through the wheel spokes and it is gouging partially across the surface. The other part of the surface is slick. I checked the other 3 brake rotors and they are slick as a whistle, so the brake pad has somehow gotten into the rotor or a foreign object got in there, not sure yet, but it will be checked out and corrected. I'll let you know what I find.
Old May 31st, 2017, 09:56 PM
My wife drives a 2014 Ford, Explorler , Limited, four-wheel-drive. We now have 53,000 miles on it and have had no issues at all"
Old November 27th, 2018, 06:37 PM
The Bone's Avatar
The Bone The Bone is offline
Liked 3 Times in 3 Posts
I bet something got logged in one of the rivet holes. At least I hope it's that simple
Old August 10th, 2019, 11:50 AM
a2t's Avatar
a2t a2t is offline
Ive had this happen before when a rock got between the pad and rotor. Its common.
Take the pad off and see how bad its gouged, you may be able to have a shop turn the rotor to save it. If not, I would replace rotors and pads on both sides of that axle.
a2t , CMelder , glc , harrison28 , JSoko , skatebowd , The Bone
TGG 1304 - Rotor Runout Two Guys Garage Two Guys Garage 0 July 21st, 2014 03:50 PM
rotor swap bigdels 1992-1996 Ford F150
3 March 17th, 2013 11:08 AM
Brake Rotor BigBlue79 1980-1986 Ford Bronco
0 November 1st, 2011 07:03 PM
How to Replace the Front Rotor on a Ford Ranger JSoko Garage Talk: Shop Class 101 0 November 1st, 2011 01:46 PM
Front Brake Repair 97-03 F150 DIXIE FIX Garage Talk: Shop Class 101 2 August 28th, 2010 04:27 PM
brake , front , gouged , rotor
