Quantcast clutch and headlight help - Ford Truck Club Forum
Old November 18th, 2017, 09:29 PM
Hammerandsaw64's Avatar
Hammerandsaw64 Hammerandsaw64 is offline
Default clutch and headlight help
Good evening. I have just recently purchased a 89 F-250 4x4 in pretty good shape barring a couple(well,more than a couple)things,but I will start here. It has been sitting for a while,and after getting it running, I tried to put it in gear to no avail. Clutch is very close to the floor and doesnt do anything when I push it in. Its very stiff and when I got under the dash to check it, the module which I think is the safety start module is missing. asked the previous owner and he prodced one he bought to replace the one that was there originally. He said it was removed to bypass the safety switch. Would this alone cause the no clutch issue or do I have bigger problems to address? The second issue is the headlights. They come on and work fine,but when I hit the dimmer switch,they go off. Hit it again,and they come back on. I'm sure I could trace it out and find the issue, but I'm going to be lazy and ask for help.
Old November 19th, 2017, 01:41 PM
Liked 115 Times in 111 Posts
You do have a mechanical or hydraulic clutch issue, just the absence of the safety switch won't cause that problem. You may be looking at dropping the transmission and rebuilding the clutch.
Obvious thing to check for the headlight issue is the bulbs. The high beam filaments may be burned out. Next thing to check is the dimmer switch itself.
glc , Hammerandsaw64 , Harlan , harrison28
clutch slave harrison28 Garage Talk: Engine & Drivetrain 1 March 25th, 2016 06:26 AM
Clutch master cylinder brick13 1992-1996 Ford F150
8 August 31st, 2013 12:06 PM
New to me 1995 - clutch doesn't release tinker1980 1992-1996 Ford F150
12 June 2nd, 2012 04:10 PM
How to Bleed the Clutch on a 1995 F-150 JSoko Garage Talk: Shop Class 101 0 May 3rd, 2012 07:44 PM
Hydramax Hydraulic Clutch Gearz Gearz 0 August 15th, 2011 10:28 AM
clutch , headlight
