Quantcast 1969 f100 240 ignition issues - Ford Truck Club Forum
Old May 14th, 2019, 10:13 PM
green machine's Avatar
green machine green machine is offline
Default 1969 f100 240 ignition issues
Recently bought this truck a old Montana forest service truck.It ran when I got it, but not very well. I put a new carb on it and it was running pretty good. I drove it 20 miles, shut it down for 5 minutes and it would not restart. After a 65 dollar tow bill got it home. I did not have any spark. It had point conversion dynalife solid state kit so I took that out and put the old points back in that were in the glove box. I did get the truck to start, but it is only firing on cylinder 1 and 5. New plugs and coil. Power at coil is 6-7 volts. New battery. Not sure what is going on. Do I have a low voltage issue, bad plug wires and bad distributor? There is not that much to it, but haven't figured it out yet.
Thanks,
Old May 15th, 2019, 12:40 AM
Liked 110 Times in 106 Posts
I believe that's normal - there is a ballast resistor that drops the voltage after it starts. I'd change the plug wires, cap, and rotor on general principles.
harrison28 (May 15th, 2019)
glc , green machine , harrison28 , JedCrone , Russellhenry24
Turn signal issues 79 F100 Terrance 1948-1983 Ford F100
1 February 1st, 2018 01:10 PM
OEM wiring harness 1969 F100 pasford 1948-1983 Ford F100
1 July 4th, 2013 09:03 AM
how do i remove ignition lock ? joe250 1973-1991 Ford F150
11 April 22nd, 2013 08:32 AM
1969 Camaro - ACDelco - Ignition and Oil Change - LS Two Guys Garage Two Guys Garage 0 April 3rd, 2013 10:51 AM
ignition problems. Motormike 1948-1983 Ford F100
5 November 14th, 2012 09:37 AM
1969 , 240 , f100 , ignition , issues
