Quantcast 1997 F250 351w E40D - Ford Truck Club Forum
Old November 28th, 2019, 09:14 PM
GentryJr's Avatar
GentryJr GentryJr is offline
Default 1997 F250 351w E40D
So my truck had been sitting for awhile, It cranks fine, but seems to have an issue when I press the accelerator it sometimes doesnít want to go, also it wonít go over 40 to 45 mph, Iíve changed my TPS, plugs, distributor cap, rotor, fuel filter, oil, and oil filter along with the air filter, now today I was messing around with it, I tried to get it to go, I started in low gear 1, then shifted to 2 then around 30 mph to 3rd, it seemed to work a lot better but still wonít go over 40/45 mph, I also was thinking that maybe itís a transmission issue, because today it threw a check engine light, I couldnít check it cause I donít have a reader, but if Iím not mistaken I believe itís a 4 gear transmission, so I ordered an transmission output sensor and some new spark plug wires today, I also was thinking of changing the mAp sensor but didnít want to get to crazy, now on these transmissions is the transmission output sensor for my year on the differential itís a 3/4ton? Any help would be most appreciated as I really love my baby
Old November 28th, 2019, 09:16 PM
GentryJr's Avatar
Also it’s an automatic so when I say shifted I mean low gears to drive
Old November 29th, 2019, 01:02 AM
I would highly suspect the MAP sensor. Also, I'd check the cats and the rest of the exhaust for blockage and excessive backpressure. You definitely need to read the codes, parts stores generally do that for free. However, most parts store scanners can't read transmission codes if it's OBD2.
harrison28 (December 2nd, 2019)
Old December 1st, 2019, 09:18 PM
GentryJr's Avatar
Thank you sir, I’ll do that
« Door latch cable replacement w/E door locks | There is no next thread »
GentryJr , glc , harrison28
HELP! 1997 f250 cold problems anavaho 1992-1997 Ford F250 | F350
1 November 16th, 2017 11:01 PM
1997 351W EFI... Thesmanman 1992-1997 Ford F250 | F350
0 October 5th, 2017 11:29 AM
1997 f250 Manny_361 New Member Introductions 3 April 10th, 2017 01:53 PM
1997 f250 parts cdv Auto Parts Wanted
0 January 30th, 2017 06:43 PM
Buying a 1997 f250 for parts?? labrat 1999-2007 Ford F250 | F350
2 February 26th, 2015 09:15 PM
1997 , 351w , e40d , f250
