Clicking noise? - Ford Truck Club Forum
Old January 1st, 2010, 11:08 AM
V8_Feller's Avatar
V8_Feller V8_Feller is offline
Images: 1
Default Clicking noise?
Every time I take off from a stop there is a clicking noise, my friend says it sounds like the axles is sliding out. I trust his judgement since he knows a lot about trucks, but I want your opinion. Even does it when I shift from reverse into drive.
2004 F-150 Heritage 4.6
218.7 RWHP, 3980 lbs, 0-60 7.72 seconds :)
Old January 1st, 2010, 01:28 PM
Old Blue's Avatar
Old Blue Old Blue is offline
Images: 384
Worn U-joint maybe....
Monthly Recognition Moderator
Check out my videos HERE
Old January 1st, 2010, 01:45 PM
marmaduke's Avatar
marmaduke marmaduke is offline
If its happening when you step on gas it might be a exhaust manifold leak.
A KICK IN THE ASS IS STILL A STEP FORWARD
Old January 1st, 2010, 02:15 PM
V8_Feller's Avatar
Images: 1
When I let off the brake. Its only one click everytime.
Old January 1st, 2010, 02:21 PM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
when you let off the brake, before you step on the gas?
Big T
Old January 1st, 2010, 02:53 PM
V8_Feller's Avatar
Images: 1
Adactly. Only sometimes though, sometimes it wont stat until I hit the gas a bit. Sometimes its right when I let off the brake. Sounds like a coin rolling around.
Old January 1st, 2010, 02:59 PM
BigT67's Avatar
Images: 262
when is the last time you greased the undercarriage?
Big T
Old January 1st, 2010, 03:38 PM
V8_Feller's Avatar
Images: 1
N/A.
Old January 1st, 2010, 03:41 PM
BigT67's Avatar
Images: 262
I would make sure the shackles are tight, particularly in the front, and check the u-joints.
Big T
Old January 1st, 2010, 03:50 PM
V8_Feller's Avatar
Images: 1
I dont have shackles up front, IFS
Rear ones are tight, but I will check everything over.
I already checked my drive shaft no play so I can't see it being a U Joint.
mmacak06
Supercharger Type Whining Noise after Cam Phaser Replacement RedHot150 2004-2008 Ford F150
118 August 13th, 2009 11:48 AM
clicking , noise
