January 16th, 2010, 10:21 PM
Ford engine classifications...
Something that's always bothered me is hearing people classify Ford engines as big blocks and small blocks.... true some are bigger than others, but there are no such animals as a Ford big, or small block... that was a Chevy thing.... Ford's are classified in series, or families....
as such...
Flathead series/family
136, 221, 329, 255, and 337
Lincoln Y series/family
279, 302, 332, 317, 341, and 368
Ford Y series/family
239, 256, 272, 292, and 312
FE series/family
332, 352, 360, 361, 390, 406, 410, 427, and 428..
FT series/family
330, 359, 361, 389, and 391..
MEL sereis/family
383, 410, 430, and 462..
Super Duty series/Family
401, 475, 477, and 534
90 Degree/Windsor series/family
221, 255, 260, 289, 302, and 351W
335 series/family
351C, 351M, and 400
385 series/family
370, 429, 460, and 514
Modular series/family Had this sent to me so thought I'd post it..
4.6, 5.4, 6.8
First 2 are V8 and the last one is a V10. Then there are various sub classes, 2,3,4 valve, Windsor or Romeo, etc. Not all combonations exist, no 4-valve 6.8 for example.
Then there is the new 6.2 hurricane V8. Too little info out there to tell if it falls into the mod motor class or not. Presumably not. It was designed on a wider bore spacing then the typical mod motors for increased bore size. But it may or may not be considered a mod motor in the future once we start learning more about it. Too new to really know anything about it.
There are a couple more V8s. The Taraus SHO V8 that was very short lived. Then there was a Jag that had a Ford V8 a couple years back.
There are the classifications of Ford engines, in the future when you hear some one call a 460 a big block, or a 302 a small block, or a 351C or M a big block, please point and laugh at them for doing so...
January 16th, 2010, 10:31 PM
had this PM'ed to me on another site... pretty much what I said but is a little more detailed...
Here's the site it came off of, so I can't take the credit for it... http://www.fordclassics.com/enginespecs.html and here's what it says..
Ford 90 Degree Family
221 cubic inch
Bore and stroke of 3.50 X 2.87.
One of the rarest engines in its' class.
Produced from 1962 to 1963
Compression ratio of 8.7:1
143 Horsepower
260 cubic inch
A hybrid of the 221.
Bore and stroke of 3.80 X 2.87
Larger intake and exhaust ports.
164 Horsepower
Was used in one of the first Cobra's.
289
Bore and stoke 4.00 X 2.87
200 Horsepower w/ 282 ft-lb torque
Two barrel Ford carb
Hydraulic camshaft
In 1964, the 289 was available at 210 horsepower, four barrel carb, cast iron intake manifold and compression ratio of 9.0:1
In 1965 the 289 became was now at 225 horsepower, larger four barrel carb and a compression ratio of 10.0:1 This engine was available till the 1967 model year.
In 1968, the engine was reduced to 195 horsepower.
289 HiPo
Available from 1964 to 1967
Higher nodularity content in block w/ larger two bolt main caps.
Counter weight balanced crankshaft.
3/8 inch rod bolts
Screw in rocker studs w/mechanical lifter camshaft.
Dual point distributor.
Ford 480 cfm four-barrel carb atop a cast-iron intake manifold.
271 horespower at 6,000 RPM w/312 ft-lb's of torque.
302
Produced in 1968
Cast iron crankshaft
forged rods
cast pistons
hydraulic camshaft
available with 2 or 4 barrell carburator
horsepower varied from 210 to 230 depending on carburator.
Standard 302 was equipped with 2 barrel from 1969 to 1983.
302 Tunnel Port
Did not see production for consumer market.
Commonly referred to as the 302 TP for Tunnel Port
Pushrods were fitted inside a sleeve
Intake ports were oversized
Intake/Exhaust was 2.12inches and 1.54inches
Two versions available, one with conventional rocker arms for the Trans Am race series and the other using Nascar shaft mounted rocers.
Engines were built by Ford foundry and not by the racing circuit
302 Boss
Top performer of the 90 degree family.
Production from 1969 to 1970.
Available in Mustang 302 Sportsroof and Mercury Cougar Eliminator only.
Four bolt mains
Screw in frost plugs
Canted valves, 2.23 in. / 1.71 in.
Cylinder heads from Ford's 335 Series family.
Threaded rocker arm studs
Push rod guide plates.
Stamped steel sled-fulcrum rockers
Mechanical lifter camshaft
dual plane, single four barrell aluminum intake.
Holley 780cfm carb.
351 Windsor
Not to be confused with the 351 Cleveland.
A basic 302 with extended deck height with thicker cylinder walls
Primarily the only interchangeable part are the heads with other small blocks from the 90 degree family.
In 1969, the 351 Windsor reached its' highest horsepower rating of 290 at 5800RPM
Ford MEL Series
In 1958, came the introduction of the MEL series engines. These were some of the largest and heaviest V8 engines Ford had ever built.
383 cubic inch
Developed for the Mercury line of vehicles.
Bore and stroke of 4.30 X 3.30 inches.
Had a two year history starting in 1958 and lasting till 1960
Most of these engines in the two years were known as the Marauder
The Mercury Marauder engines of 1958 came with either 312 horsepower or 330 horsepower, both packed with a four barrel carburator.
In 1959, the Marauder engine was considered a mid range of its' predecessor with a stock horsepower of 322.
In its' last year, the 383 cubic inch Marauder was dropped to 280 horsepower.
410 cubic inch
Less common of the MEL series is the 410 cubic inch
Bore and Stroke of 4.20 X 3.70
10.5.1 compression
Holley four-barrel carb and hydraulic lifters.
475 pounds of foot torque
Also be reffered to as the E-475 engine.
In 1958, Edsel Corsair and Citation models used the 410 cubic inch as their only preference for engine types.
430 cubic inch
commonly referred to as the Bulldozer of the MEL series and lasted from 1958 to 1965
In its' "suped up" version, the 430 was commonly referred to as the Super Marauder and came with three two barrel carburators.
bore and stroke of 4.29 X 3.7 inches
Compression rations started at 10.5.1 but soon began to decline late in 1959 to 10.0.1 at 350 horsepower.
The higher horsepower versions of the 430 remained within its first year of production with horsepower of 365, 375 and of course 400.
In 1959 the horsepower slowly began to reduce, yet hold a moderate 345 ponies even with a slightly less compression ratio of 10.0.1.
In 1960, the big 430 cubic inch used a milder camshaft, producing 315 horsepower.
1963 when the 430 got an overhaul with new pistons and a four barrel carb, pushing compression to 10.1.1 and a horsepower rating of about 345.
It could be found in the 1958 Lincoln Continental Convertible, rating 400 horsepower and nearly 500 foot pounds of torque.
Mercury also used the 430 cubic inch until 1960.
462 cubic inch
By 1966, it replaced its' predecessor the 430.
bore and stroke of 4.38 X 3.83 inches.
hydraulic lifters and a four barrel carb.
the 462 was used for its' smoothness in large passenger vehicles.
It lasted for only two years.
Ford FE Series
332 cubic inch (1958 - 1959)
Compression ratio 9.5:1
Bore and stroke of 4.00X3.30
two-barrell @ 240 hp
1958 series option w/four-barrell @ 265 hp
mechanical camshaft w/machined combustion chambers
last year of production, compression ratio 8.9.:1 @ 225 hp
352 cubic inch
bore and stroke of 4.00X3.50
engine for the '58 T-bird
four barrell carb @ 300 hp
compression ratio 10.2.:1
cast iron crankshaft
forged steel rods, mechanical-lifter camshaft w/machined combustion chambers or cast chambers by 1959.
By 1960, the 352 HP was available with an aluminum intake manifold producing approximately 360 hp.
360 cubic inch
Used in Ford trucks
Lower compression engine with heavy duty internal parts
361 cubic inch (1958 - 1959)
Bore and stroke 4.0469X3.50
10.5:1 compression ratio w/303 hp
In 1959, the 360 cubic inch used cast chambers reducing compression and horsepower.
390 cubic inch (1961-1976)
Bore and stroke 4.05X3.78
Three versions available
1961-1963: 390 cubic inch with 9.6:1 compression ratio, four barrell carb @300 hp.
406 cubic inch
Introduced in 1962
Bore and stroke 4.13x3.78
Same block as 390 HP
Few 1963 blocks came with cross bolt mains.
Revised oil galleries.
410 cubic inch
This is a 390 block with a 428 crankshaft
Four barrell carb.
The stroke is increased .020 in for a total of 3.98 inches
Only used in Mercury vehicles from 1966 to 1967
427 Low Riser
Available through 1963-1964
Cast iron crankshaft and solid lifter camshaft
Intake 2.04 (2.09 inch in 1964) with 1.66 exhaust valves
Some of these engines had cross-bolt mains.
Cast aluminum intake manifolds.
Single and dual four barrell carburators.
Horsepower varied from 410 to 425 depending on setup.
11.5.1 compression
427 Medium Riser
1965 to 1967 all 427 blocks were side oilers.
Forged steel crankshaft
Cap screw connecting rods
Cross bolt mains
427 High Riser
Introduce in 1964
Tallest cyclinder ports and intake manifold allowed for greater air/fuel mixture
Cast iron crank
Cross bolt mains
427 Tunnel Port
Available in 1967
Options included Tunnel Port cyclinder heads, four barrell aluminum intake or dual four barrell aluminum intake.
Much like the 427 medium riser in all other regards.
427 SOHC
Available as an over the counter option only.
Cast aluminum cyclinder heads
hemi-spherical combusiton chambers
stainless steel valves
428 cubic inch
Introduced in 1966
Bore and stroke of 4.13X3.98
forged-steel connecting rods
345 horsepower @ 10.5:1 compression ration
Variations of the 428 existed throughout its' life span, including the 428 Police Interceptor, 428 Thunderjet and 428 Marauder.
The Police Interceptor contained an aluminum intake, high performance camshaft and beefier connecting rods to produce 360 hp.
428 Cobra Jet
Standard was 2.09 inch intake and 1.66 inch exhaust valves.
Cast iron intake manifold identical to the aluminum one on the police interceptor.
Cast iron exhaust manifolds.
Two-bolt main block
Between 345-360 horsepower
428 Super Cobra Jet
Internal structure differences included Lemans type cap screw rods
The capscrews were shorter than the 427's to clear the block
Externally balanced
External engine oil cooler
Ford 385-Series Family
Although there were several variations to the engines of the 385-series family, only two displacements were available---the 429 cubic inch and the 460 cubic inch. Both were introduced in 1968 and lasted until 1973. These engines were heavier and larger than Ford's predecessor---the FE Family.
429 (Thunderjet)
two-bolt main bearing cap
Bore and Stroke 4.36x3.59
cast-iron crankshaft
forged-steel connecting rods with 3/8 inch rod bolts
cast-aluminum pistons
hydraulic lifter camshaft
2.08 inch/1.66 inch intake/exhaust valves
non-adjustable rocker arms
4 barrel or 2 barrel carburator
Was available in Ford and Mercury automobiles
429 Cobra Jet
Four-bolt main engine block (with exception to some early 1970 models).
Larger cylinder heads---2.25 inches/1.72 inches intake/exhaust.
Rocker arms were stamped steel 1.73:1 ratio with sled type fulcrums, threaded screw-in rocker studs and pushrod guide plates.
The rocker arms on the 429 cubic inch Cobra Jet were also adjustable prior to 1969.
Cobra Jet used a Rochester Quadrajet carburetor atop a spread-bore cast-iron manifold.
429 Super Cobra Jet
4 bolt main engine blocks
Forged aluminum pistions
Adjustable rocker arms
780cfm Holley four-barrel carb
429 Boss
All aluminum cast cylinder heads
Cresent type combustion chambers
Intake/Exhaust valves of 2.28in and 1.90inch
Exhaust valves are "D" shaped
4 oil galleries
Identified by casting 429HP on block
Higher iron nodularity content with thicker cylinder walls
2 Versions of the 429 Boss existed, they were 820-S & 820-T
Forged steel cross-drilled crankshaft
Forged aluminum pistons
Aluminum dual plane manifold w/735cfm Holley four barrel carb
429 Nascar
Larger Outboard bolts in #1 main bearing cap.
Deck height was grooved for O rings.
Larger machined refliefs for exhaust pushrods
Longer street rods, than the Boss 429-820S type
Some blocks had full hemi design, others crescent type
Stainless steel intake valves
Magnesium valve covers and intake manifold.
460
Produced from 1968 to 1996.
Available in Ford, Mercury and Lincoln.
Same as 429, but with longer stroke. (3.85 inch)
During its earlier years, pre 1973, horsepower was rated at 365. After 1972 horsepower ranged from 208 to 275.
Intake/exhaust valves are 2.08/1.66
Intake/exhaust valves for the Police Interceptor 460 heads (from 1973-'74) measure 2.19/1.66
Ford 335-Series Family
The 335 Series consisted of versions of the 351 and 400 blocks. It lasted from 1970 to 1975.
351 Cleveland
canted-valve cyclinder heads.
bore and stroke of 4.00 X 3.50.
a light weight block to beat.
one of the most desirable V8 engines Ford had to offer.
a two barrel or four barrel setup.
From 1970 to 1971 the 351 boosted between 250 to 240 horsepower.
As time progress, the 351 Cleveland saw lessor horsepower until its' demise in 1975.
the 351 Cleveland four barrel came with dual exhausts, a higher compressions ratio, larger intake/exhaust valves and four bolt mains during the first year of production.
the 351 Windsor, which belongs to the 90 degree V8 family and bears no resemblance or connection to the 351 Cleveland.
351 CJ
Introduced in the fall of 1971
mostly of four bolt mains, however there are some with two bolt mains.
possessed a spread bore bolt pattern cast iron manifold
Autolite carb 4300-D
Horsepower varied from approximately 280 during the first year of production down to 265 by 1973.
351 Boss
Most desirable
only available in the 1971 Boss 351 Mustang
Four bolt mains
high nodular iron crankshaft
solid lifter camshaft with screw in studs
adjustable rockers
an aluminum four barrel intake
351 HO
In 1972, Ford rolled the 351 Boss over into the 351 High Output for the new year.
Slighltly less desirable, the 351 High Output used the spread bore bolt pattern cast iron manifold
Autolite 4300-D.
With a milder camshaft, the output of the 351 HO was about 275 horsepower.
351 M and 400
By 1975 the 351 Modified was issued with Cleveland heads
a two barrel carb.
hydraulic lifters.
a cast iron intake manifold.
a two barrel carb.
the 351 Modified and the 400 which was introduced since 1971, are virtually identical with very few exceptions.
Ford Y Block Series Family
239 cubic inch
Cast iron crankshaft, intake and exhaust
Cast-aluminum pistons
Mechanical camshaft
Aavailable in Ford cars in 1954 and 1955 Ford trucks
256 cubic inch
Used only on Mercury vehicles and in F-series Ford trucks
Compression ratio of 7.5:1
161hp at 4400RPM
272 cubic inch
Two versions available for 1955
Two barrel carb with 7.6:1 compression and 162hp
Four barrel carb with 8.5:1 compression and 182hp
In 1956 horsepower varied with automatic or manual transmission
In 1957, the 272 cubic inch reached 192 horsepower
292 cubic inch
First introduced in the T-bird and Montclair
All used four barrel carb in 1955, but horsepower varied, but average around 200 depending with manual or automatic transmissions.
Bore and stroke: 3.75x3.30 in.
Following years were produce less horsepower, until its' demise in 1964
312 cubic inch
Largest Y Block of its kind
Bore and stroke: 3.80x3.44 in.
Two versions were introduced, both with four barrel carbs and dual exhausts.
Introduced, once again in the 1957 T-Bird, it gained critical aclaim for producing horsepower over 300 while equipped with a Paxton supercharger
Lincoln Family
317 cubic inch
Cast nodular iron crankshaft supported by five bearing journals at 2.62inch
Rod journals measured 2.249 inches
8.0:1 compression ratio and 205hp at 4200 RPM
An improved Holley carb, high lifter cam, dual diaphram distributor and freer flowing exhaust
341 cubic inch
Last only for 1955
Increased bore to 3.94 inches
Compression ratio of 8.5:1 with 225hp at 4400RPM and 332ft.lb of torque
368 cubic inch
Introduced in 1956
Increased bore and stroke to 4.00X3.66
285hp @ 4600 RPM with 402ft.lb. of toque
Compression ratio is 9.0:1
Larger exhaust valves at 1.64 inches, bigger fuel pump and dual diaphram distributor
Black painted valve covers and air cleaner
Following production year had slightly revised enhancements including 10.1:1 compression, Carter four barrel carb and a spin on/off oil filter
January 16th, 2010, 10:59 PM
good post!
October 30th, 2010, 12:13 PM
Liked 22 Times in 18 Posts
What about all of the inline six models made throughout the years. There sure are a lot of em.
October 30th, 2010, 01:35 PM
Liked 14 Times in 11 Posts
Good question Russo, why dont you see what you can come up with and add it to this thread. Or make your own thread with the info in this section!
October 30th, 2010, 05:11 PM
I'll see what I can do, I often do research on the inline six family and they are actually classified as big a small block 240 and 300 being big block and those smaller than that used long long ago were considered small blocks.
| Thread Tools |
| Display Modes |
Linear Mode
(View-All)
Members who have read this thread : 13
BigBlue79
bigdave54
D&J2007F150
Daniel Baker
DoubleDee
Ilean
Jonicker
JSoko
Per-Arne Hauglund
PKurt
Russo2
volvering
whitesleeper
