Quantcast 78 Bronco VIN decode - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1978-1979 Ford Bronco
Old February 10th, 2010, 12:56 AM
Al Mc's Avatar
Al Mc Al Mc is offline
Default 78 Bronco VIN decode
could some one help me decode VIN U15HLA7891
thanks
Old February 10th, 2010, 02:02 AM
thanks
Decoding a 1978-1979 Bronco VIN number
Series: U15 = U-100 Wagon
Engine: H = 351 Mci 5.8L V8 2BC
Plant: L = Michigan
Build Month: A7891 = August of 1978
I hope this helps.
Old February 10th, 2010, 02:39 AM
the only thing I didnt see on that list is trans webby
Old February 10th, 2010, 09:12 AM
The 1978-79 Broncos, the VIN plate is attached to the rear face of the
driver’s door. The information (VIN nmbr.) on the tag only identifies the
Series, Engine, Assembly Plant, Month, Year and Production Sequence.
Example: U15 H L A 78 91
Old February 10th, 2010, 09:16 AM
Johnny's Avatar
Johnny Johnny is offline
Yep.....
Old May 28th, 2012, 06:23 PM
steepwater's Avatar
steepwater steepwater is offline
I was looking at the vin on my 78 and mine doesn't follow with the sequence at the end. its U15SLCG2449
Old May 28th, 2012, 06:42 PM
Give me a minute to research.
Blue.
Old May 28th, 2012, 06:51 PM
U15= 4 wheel drive Bronco Wagon
S= 6.6L 400
L= Michigan truck
You're consecutive unit number(the CG2449) is just fine, it's AE0,001 to CK9,999 for a 1978 Bronco.
Old May 28th, 2012, 08:59 PM
steepwater's Avatar
thank you
Old May 28th, 2012, 09:37 PM
No problem, if you want the whole tag decoded I can do that too.
« Looking for Bushwacker Extend A Flares | There is no next thread »
(View-All Members who have read this thread : 71
a1speedracing , Alexemami , Allahemrt , Anthonysib , BaltoMoJoe , BennyloR , BigBlue79 , Billygenna , Booba5185 , BrianRed , CharlesCor , Charlessam , ClezeripLover , CrystalTiedY , DanielmaR , Davidsot , DeweyFum , Dokassell , DonnieGow , Dorothycraws , ErnikaOdowl , Franciswem , GeraldHek , glc , Grainecofs , harrison28 , HarryEmort , HawaiianF150 , HearttcoreGerda , Irinagluch , IsreallEm , JasonDerve , JeffreyKeX , Jendiump , JesseEcold , Jesseplosy , JohnnyWIB , Josephtok , Klitch , Larrydib , Michaelanify , Nastyaerund , PatrickNocky , Petrrarc , Raleigh , RalphGob , Ralphideri , RenatoVoics , Richardkig , Ridgejott , Robertcem , RobertEmavy , RobertVog , Rodneyvat , RonaldFon , Russo2 , sbpbrent , SemmionsCom , Shanehib , sochi.cat/vek , steepwater , TimothyNut , Travisappef , Williamidons , Williamrhync , WilliamStali , Williamtat , XRumerTest , Zacharycrelf , ZacharyThync , ZourExtit
Another good looking Bronco BigT67 1987-1991 Ford Bronco
6 July 3rd, 2012 05:39 PM
bronco big bad 79 mudman New Member Introductions 7 July 10th, 2010 03:32 AM
4 July 8th, 2010 09:43 PM
Looking For New or Used Flares for 95 Bronco 7.62Jake Auto Parts Wanted
2 April 13th, 2010 05:07 PM
Bronco man fasterthanu1973 New Member Introductions 17 January 6th, 2010 03:44 AM
bronco , decode , vin
