Quantcast 1999 F350 Super Duty 7.3 With Turbo Issue - Ford Truck Club Forum
Old February 15th, 2010, 12:49 PM
mustang512's Avatar
mustang512 mustang512 is offline
Default 1999 F350 Super Duty 7.3 With Turbo Issue
i have a 99 f350 superduty with a 7.3 and when the ambiant temp gets to below 50 degrees the turbo doesnt work right when it is not under a load but does if under a load
Old February 15th, 2010, 04:06 PM
I would say to look at the sensor first. May be a faulty sensor.
Old February 15th, 2010, 07:12 PM
mustang512's Avatar
which sensor r u recomending
Old February 15th, 2010, 08:36 PM
Old Blue's Avatar
Old Blue Old Blue is offline
Images: 384
what do you mean by it not working right?
Monthly Recognition Moderator
Check out my videos HERE
Old February 15th, 2010, 08:39 PM
V8_Feller's Avatar
V8_Feller V8_Feller is offline
Images: 1
Are you building boost at all?
My 7.3 did this before it warmed up I would only throw a couple pounds of boost. Also I know back around then some F-150 sensers dont work well in the cold, I wonder if you got that?
2004 F-150 Heritage 4.6
218.7 RWHP, 3980 lbs, 0-60 7.72 seconds :)
Old February 15th, 2010, 09:32 PM
the 7.3 likes to build heat by playing with the wastegate. is this the feeling your talking about?
Old February 16th, 2010, 01:42 PM
Welcome to the site
send $$$ and in return I will ship Majic Wand
Are you running a Programer/tuner??
Old February 16th, 2010, 04:01 PM
mustang512's Avatar
no i donnt have any programers and yes it is the waste gate isue but i dont no what to do about it
Old February 16th, 2010, 04:47 PM
Lostin90s's Avatar
Welcome to FTC
Old February 16th, 2010, 11:01 PM
I dont think you can get around that surging feeling your getting. Its trying to build the engine temperature. Does it go away when you've hit operating temperatures? If it doesn't then you may have a problem.
Bathexpert , DoubleDee , ericmiller181@gmail.com , I_drive_over_prius , Jbigfoot21 , kwkcak , Ol Red , tcasebeer , whitesleeper
2011 Ford Super Duty 6.7L Powerstroke Bates88 Garage Talk: General Tech Talk 6 May 1st, 2011 12:11 AM
New Release by Bushwacker > 2011 Super Duty Bates88 2011-2016 Ford F250 | F350
0 May 21st, 2010 02:17 PM
Super Duty Raptor RedHot150 General Discussion
4 May 11th, 2010 07:19 PM
1961 Ford F-950 Super Duty marmaduke Ford's Not Listed 5 March 2nd, 2010 10:15 PM
2011 Ford Super Duty RedHot150 2011-2016 Ford F250 | F350
5 October 17th, 2009 06:30 PM
1999 , duty , f350 , issue , super , turbo
