Quantcast Gas gauge issues - Ford Truck Club Forum
Old July 10th, 2010, 11:55 AM
nismo972's Avatar
nismo972 nismo972 is offline
Default Gas gauge issues
Hey Guys having an issue with my gas gauge. When im driving the low fuel light will come on and the needle on the gauge will bottom out. Sometimes it will correct itself if I turn it off for awhile and sometimes it will correct itself over a period of time. Bottom line i could just get gas and the thing will read full and bottom out all of a sudden.
P.S im not losing any gas
Old July 10th, 2010, 12:29 PM
Images: 616
Liked 167 Times in 149 Posts
this seems to be a common problem
mostly reported is that when filling up the needle will not go to full for some time
if you have dual tanks its the selector switch on the dash
if not try this; disconnect the battery and reseat the relays in the fuse boxes; you may find one loose; look under the hood and in the kick box inside; not sure where this one is located
jiggle them around and then plug them back in
it can't hurt
PS: as far as not losing gas, try eating more collard greens & black eyes; it well help loosen you up
Old July 10th, 2010, 07:22 PM
If its the 04 your profile mentions, your probably looking at a sending unit on its last leg, or a bare wire.
ames8722 , dsb12 , Russo2 , shree12
3 July 21st, 2013 10:10 PM
Gauge Opinions Needed nine5flareside 1992-1996 Ford F150
17 May 3rd, 2010 08:19 PM
4x4 Issues - 97 Klitch 1997-2003 Ford F150
33 January 3rd, 2010 02:57 PM
gas , gauge , issues
