Quantcast Problem with gas gauge - Ford Truck Club Forum
Old July 18th, 2010, 03:22 PM
Jarhizzy's Avatar
Jarhizzy Jarhizzy is offline
Images: 8
Default Problem with gas gauge
Hello I own a 1994 Ford Ranger XLT 4X4 5 speed 4.0L. Owned the vehicle for about a month now and was wondering why my gas gauge does not work right. When the truck is off, the gauge shows the correct amount of gas in the truck. when i start and drive the truck, it shows empty. My thought is that the wires are on backwords some where or theres a ground issue so that when it is off, the gauge is on. Please let me know. its getting kinda annoying having to turn the truck off to see how much gas i have
Thanks, Ryan
Old July 19th, 2010, 08:11 AM
Images: 616
Liked 167 Times in 149 Posts
I used to just keep the tank full and watch my milage
my first thought was a hole in the float, but your guage does work
several things to check
It will be a PITA but you may have a bad ground for the instrimunt cluster; dissasemble the cluster from the dash and check the ground connection remove it and clean it with steel wool or a pincel eraser; this might help
or; you can remove the bed and check the sending unit connections which can accumulate all kind of trash, dirt, moisture, and harbor corroision; pull the connector apart and clean it and spray it with WD 40 and put it back together this may fix it
The fuel gauge and fuel sending unit are very easy to test and in about 15 minutes you will know exactly what's wrong.
First thing you need to do is check all the fuses and make sure you are getting power to the gauge. If the other gauges are working, then you can safely assume power is coming into the cluster (red/yellow wire).Then check the black/yellow wire at the fuel tank connector and make sure you have a good ground.
If power and ground are good, then ground the yellow/white wire at the fuel tank connector. If the fuel gauge goes all the way to FULL, you have a bad sending unit. If it stays at Empty, you have a bad gauge or an open in the yellow/white wire.
Ford has a special tester for the Anti-Slosh module. But if you replace the fuel level sending unit and fuel gauge, and assuming the wiring is indeed good, then it's a pretty good bet the Anti-Slosh module is bad.
heres how you can test the gauge itself, with a multi-meter
With the sending unit float arm in the empty stop position, resistance should be 15 ohms (below E). With the sending unit float arm in the full-stop position, resistance should be 160 ohms (above F). The fuel gauge should read empty at 22.5 ohms and full at 145 ohms.
for the sending unit:
With ohmmeter positive lead on the signal wire lead and the negative lead on ground, check the resistance values of the fuel sending unit at various positions of the float arm. An open circuit will indicate infinity on the ohmmeter and a short will indicate zero ohms.
for a bad harness connector: check resistance from harness connector back to PCM. you"ll need a wiring diagram; which can be had in a Haynes or Chilton Manual
the bed isn't hard to take off, just get extra help so you don't scratch it
good luck as these type of problems can be an exstream PITA
Old July 19th, 2010, 07:12 PM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
My dad used to do that for a 1970 chevy van he had. He kept a shirt pocket sized tablet and pencil on the dash and made sure he watched the odometer. He bought the van new for a race bike hauler and shortly after the gauge quit. He did the math for the next 18 years until it got parked and just rotted into the ground......
Big T
Old July 21st, 2013, 10:10 PM
Budberry's Avatar
Budberry Budberry is offline
I'm having the same problem with my 1997 f250. I am going to fill up and watch the mileage. I took the instrument cluster out and found no anti sloosh module. My next move is to take the bed off and see if the sending unit is stuck. The gauge moves to the resting position when the truck is off but only rises to one line above E. oh well could be worst I could own a Dodge
ames8722 , bikertrash3531 , Brianc , Budberry , ghp , gjohns17 , glc , ridemore95 , Russo2 , scbill , shayrun
tailgate problem tam85 2011-2016 Ford F250 | F350
8 November 6th, 2013 09:03 AM
3 July 10th, 2010 09:39 PM
Gauge Opinions Needed nine5flareside 1992-1996 Ford F150
17 May 3rd, 2010 08:19 PM
04-05 Spark Plug Problem 2004FX4F150 Garage Talk: Paint & Detailing 3 March 10th, 2010 03:35 PM
Strange HID problem 2004FX4F150 2004-2008 Ford F150
20 February 22nd, 2010 06:29 PM
gas , gauge , problem
