November 21st, 2010, 05:19 PM
4x4 problems
dose anyone know what might be causing my 4x4 to lock when i turn more than 60*. it dose it so bad that the rear wheels drag and it even kills the motor should I get the 4x4 transmission drained or is it something in the transfer case.
November 21st, 2010, 05:22 PM
Liked 4 Times in 4 Posts
What axle is it? D44 and its TTB correct?
just quick guess would be that the joint at the knuckle would be binding possibly even hitting the knuckle.
November 21st, 2010, 05:31 PM
Liked 14 Times in 11 Posts
IFS TTB front axle.
My guess is something with the front axles. What kind of hubs do you have, manual or auto locking?
November 25th, 2010, 09:41 PM
thanks klitch i jacked up my truck took the wheel off and put the 4x4 in N and spun the drive shaft and just like you thought the joints hit not allowing it to rotate. do I need to replace my axle with an inline one or replace the u joints , but why would the rear wheel opposite of the way i am turning drag.
November 25th, 2010, 10:19 PM
I believe you need to pull the whole shaft out through the knuckle, both sides and replace just the joints. Given the shafts look good, no groove cut from seals, good spline condition. This will be straight forward maintenance on the truck, no fabrication just replace parts.
I'm confused by the comment about the rear, are you saying on a right turn in 4x4, the left rear tire binds and drags? Only in 4x4?
November 25th, 2010, 10:28 PM
ya like there is something making the pasa-track do the opposite of what it is suppose to.
November 25th, 2010, 10:40 PM
I'd repair the front joints first before getting excited over the rear, though its possible the rear could need new internals such as spiders.
November 25th, 2010, 10:50 PM
Do you know if both rear wheels spin when you burn out? Chances are only one rear wheel has the power in your truck. I don't think many trucks 92 - 96 came with any LS/trac-lock units, I believe most 92 - 96 8.8's have open carriers. Mine does and I think so does ASwaffs.
November 26th, 2010, 12:30 AM
as far as i know , because when i look at the ground there is a mark from each rear tire but I'll check tomorrow and get back to you
November 26th, 2010, 01:50 AM
I honestly think if the front joints are bad, allowing them to hit knuckles and bind. You will see the rear stop spinning as well. If you bind both front shafts, the rear will feel it as well via t-case.
Remedy bad joints up front, then verify if the rear continues to have symptoms.
| Thread Tools |
| Display Modes |
Linear Mode
(View-All)
Members who have read this thread : 13
bruewayne
Dorian71
herbz
ljmathias
michaelsnodgrass18
Mtgoat
mucklife13
Stewy 39
torkum
whitesleeper
woody001
zippois1
zmr2010
