Quantcast 1999 f350 powerstroke power loss - Ford Truck Club Forum
Old February 11th, 2011, 08:00 PM
tcasebeer's Avatar
tcasebeer tcasebeer is offline
Default 1999 f350 powerstroke power loss
1999 f350 7.3 powerstroke, getting major loss of power when going uphill either with or without a trailer, max or 15 -20 mph, seems that it doesn't know when to shift. need answers.
Old February 12th, 2011, 09:13 AM
so many items to cover as fuel, exhaust, ignition
is the CEL on ?
did it just happen or has it been getting worst ?
Old February 14th, 2011, 05:23 PM
tcasebeer's Avatar
started about a year ago, we had it serviced and the said there were some pressure problems with the turbo so they changed out some fittings and tightend everything up including 2 fuel lines that were leaking, I could break out the bill for more detail, they also said the tranny needs to be serviced, after that it ran fine until about 2 weeks ago, it started doing it again, the tranny still hasn't been serviced and its due for the fuel filter to be changed also.
also not sure what the cel is
Old February 14th, 2011, 05:28 PM
tcasebeer's Avatar
and the check engine light is not on.
Old February 15th, 2011, 08:13 AM
Sounds like trans slippage to me.
Old February 15th, 2011, 08:43 AM
do the tranny & fuel filter and see what happens
there are a couple of options on the tranny
dealer flush, usually without filter change
DIY fluid & filter change at home, this will require more work on your part, which involves more than just dropping the pan
can provide details for the DIY flush if needed
Old February 17th, 2011, 08:21 PM
tcasebeer's Avatar
but if it was trans slippage wouldn't it be doing it all the time not just on hills?, or is that just when its most obvious when its under a load?
Old February 17th, 2011, 08:23 PM
tcasebeer's Avatar
yes info on the DIY flush would be helpful.
Old February 18th, 2011, 12:18 AM
2 things I've noted are practically a must for the 7.3's.
1) Pyrometer, you NEED to know your temps especially if you have a tuner
2) Boost gauge. Helps verify your getting your 18# average boost.
Old February 18th, 2011, 12:32 AM
DIXIE FIX's Avatar
Images: 504
check your fuel bowl for leaks its comon on the 7.3L and it will really kill power if its leaking.
aldrinmaclarens29 , ASwaff400 , Bates88 , bruewayne , cootersbigblackford , DIXIE FIX , DoubleDee , herbz , JSoko , Klitch , nine5flareside , Russo2 , sbellinghausen , tcasebeer , whitesleeper , Willows Wind
1999 f350 powerstroke power loss tcasebeer 1999-2007 Ford F250 | F350
0 February 11th, 2011 07:33 PM
Banks Ram-Air 2011 Powerstroke 6.7L Bates88 Garage Talk: General Tech Talk 0 November 9th, 2010 02:50 PM
Thousands face job loss when part of stimulus expires BigT67 General Discussion
0 September 25th, 2010 11:34 PM
2011 F350 6.7L Powerstroke Bates88 2011-2016 Ford F250 | F350
5 September 24th, 2010 06:53 PM
1999 F350 Super Duty 7.3 With Turbo Issue mustang512 1999-2007 Ford F250 | F350
17 February 18th, 2010 09:09 PM
1999 , f350 , loss , power , powerstroke
