March 17th, 2011, 06:12 PM
Gott's Mod 2004-2008
Howdy once again for another installment of How-To's. This time I'll be tackling the easy (cough) to do Gott's Mod. We have another how-to for the 2009 and newer models, but not one for the 2004-2008 models. This mod is a simple (cough) and cheap upgrade that opens up your air intake. This portion that is being upgraded is the part inside the fender well (some refer to it as the snorkel, as will I during this how to) to the air filter or the suck hose for you 5.4L guys. Also, upon researching other resources, it looks like this should be applicable to the 1997-2003 F150's as well.
The stock snorkel for my truck (4.6L V8) is approximately 5" long with an inlet diameter of ONLY approximately 2". We're going to increase that inlet to 1.5 times the original, to 3"!
Project time: 3 hours
Time to sand: 2 hours
Cost of parts: $11.15
Cost of supplies: $15.81
First, let's start with the tools I used:
Now, I don't recommend using a detail sander like I did, but that's what I had on hand. I used 80 grit to do the heavy sanding, then went to 120 and finally finishing with 220 grit. That was the cost of supplies for me was the sanding sheets. For the saw, all I had was a coping saw. If you have a regular hack saw, or even a band saw, more power to you.
Parts needed:
2' section of 3" Sch 40 PVC pipe, 4.95 @ Home Depot. 3" coupler also from Home Depot for $6.20.
Time to do some cutting:
5" total length to be used. 3" of which will be sanded to fit into the fender hole.
Taking apart your intake system:
EDIT: The hose that is labeled as the PCV hose is incorrect. I think this is just a breather tube. My PCV valve is located on the passenger side valve cover.
This is directly applicable for you 4.6L guys. I think you 5.4L guys have it easier. Take out your filter, undo a tab or 2 and the tube will seperate from the filter housing. You should have only 1 screw on the back side near the elbow that you have to unscrew, and then just pull the snorkel out and your done. Back to the 4.6L guys, after you disassemble your intake, you'll have to separate the snorkel from the filter housing. To do this, there's a tab on the bottom side you'll have to squeeze in to disconnect. There's a square peg/button that is located next to that tab. You can either push in on this with your thumb or use a screw driver. Once you get the tab out of the hole, the snorkel will rotate up, and then you can pull the snorkel and filter housing apart.
The hole:
This is what we're dealing with, and 3 1/2 x 3 1/8-3 1/4" hole. Remember that round peg into a square hole thing? Well this is close, round peg into an oval hole. This is where the sanding comes into play.
New snorkel after sanding:
You'll have to sand 2 opposite sides down so it fits into the oval hole. I marked the pipe on the edge to indicate the 2 sides. Make sure they are directly opposite each other. This is where the majority of the sanding will take place. A note: You'll have to do some fitting as you progress, I had the issue of my sanding tapering and not being flat and uniform across the length. You can also see the marks on the pipe from the opening. This extends into the inner part of the fender, about 2" of pipe.
Comparing the old and the new:
New snorkel in place:
Filter housing attached to the snorkel:
When I started putting everything together, I put the snorkel in first, then the filter housing with the coupler attached next. I placed the coupler on the snorkel and pushed/pulled the filter housing into place until the tabs on the bottom lined up with the grommets. Tightened down the screw clamps on the coupler, and proceeded to put the intake assembly back together.
Here's what it looks like with everything back together:
Don't forget to disconnect your battery. I did mine for 5 minutes. This resets the computer, don't know if it's really necessary, but there's no harm in doing it just to be on the safe side.
Questions, comments, or concerns, please feel free to post!
Double(. Y .)Dee
SSG, TXARNG
Reason: Correction
March 17th, 2011, 07:27 PM
More air
DOUBLEDEE
I have a ?
Is the hole over all to small or just out of round .. The reason i ask was wondering if a person could take a heat gun to the pipe so one could reshape the pipe to fit the hole .. just wondering thanks
March 17th, 2011, 07:50 PM
Location: outskirts of new orleans in a city called metairie
any better throittle response or better gas mileage?
March 17th, 2011, 08:28 PM
Originally Posted by whitesleeper
DOUBLEDEE
I have a ?
Which hole? The OEM snorkel, that's only 2" round. The hole in the fender walls is about 3 1/2 x 3 1/8 - 3 1/4".
You COULD take a heat gun to it, but... that'll be a lot of stretching. The flared opening of the OEM snorkel is right at 3". I'd figure it'd be better to just replace the OEM snorkel. It's only 12 bucks and about 3 hours out of your time to do.
It's more of un restricting the flow of air and allowing the system to breathe. Example, lets all go run a mile, then I give you a straw to breathe through, while I enjoy breathing with my mouth. That's probably the best, albeit dramatic, way of describing what this mod will do for the suck part of the engine.
Haven't gone anywhere with it yet. I'll find out tomorrow when I go to the shootin' range.
Double(. Y .)Dee
SSG, TXARNG
March 17th, 2011, 09:02 PM
update us after the shootin range DD!
March 18th, 2011, 07:02 AM
nice work DD!
i did a very crude gotts mod to the expedition that didnt cost me a penny, doesnt look pretty, but it works. averaged 12.5 mpg in the city with a heavy right foot before, been averaging 13.4 mpg after, and when accelerating there is a little deeper rumble
Aaron'95 F150 XLT, reg cab long bed, swapped 351w,
4.56 gears, 4-link SAS, 14" coil overs. SAS Thread!!!
March 18th, 2011, 07:29 PM
OK, so here's the update from me going out today. I was on it harder than normal today, and with the unofficial pantsometer, results say that there's not much difference. Throttle response... no. Nothing. Sound... the same. Mileage, time will tell. I really didn't expect any difference.
Double(. Y .)Dee
SSG, TXARNG
March 19th, 2011, 08:19 AM
Well you are getting more volume of cooler air into your engine... nothing wrong with that!
March 19th, 2011, 03:28 PM
Good work DoubleDee
have you considered removing the silencer ?
March 22nd, 2011, 07:29 AM
the fitment of the 3" PVC to the fender opening, would seem to be the biggest PITA
maybe a Rasp would make it quicker to file it to fit
and for those of you that will do this, dont put that PCV on a grinder it will clog up the grinding wheel
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
(View-All)
Members who have read this thread : 25
alaskatabby
ASwaff400
Billygenna
D&J2007F150
darwin333
DoubleDee
EmersonSwone
HawaiianF150
herbz
HiRoller
imhsar
Joe'Bronco
jrohner78
JSoko
KeithFoult
nine5flareside
OGTerror
Red_2wd
Russo2
Scotts Black FX4
Stewy 39
toofastf150
tylerbotts
whitesleeper
William
