May 17th, 2011, 11:04 PM
2.5 inch leveling kit with 35' tires?
If i get a 2.5 inch leveling kit and have 35's on my truck is it going to look like it has a 5 inch lift? Are the tires going to fill out the wheel wells good enough so the truck looks aggresive? what do you think?...
May 17th, 2011, 11:06 PM
O just a guess here, but yes, tires will fill wheel wells out. Mudders fill them right up...mine would rub when I got close to full crank with stock wheels on.
May 17th, 2011, 11:12 PM
There may be slight rubbing... may need to do some slight trimming! I would suggest 33" tires.
May 17th, 2011, 11:13 PM
What did Matt have on his truck, 6" lift and 35" tires?
May 18th, 2011, 01:03 AM
Yes sir, he had a 6" Pro-Comp lift with 35's, he had Pro-Comps,then Cats used Terra Grapplers, then he bought a set of nice Nitto Trail Grapplers. He always complained about how his ass end sat lower than some other lift kits. Esp when he was parked next to Samantha who also has a 6" suspension lift without the saggy rear haha. He added a block or a leaf to get it to sit level. What else you wanna know ? haha
May 18th, 2011, 01:06 AM
33s' wont rob your fuel mileage as bad and you'll have more oomph. Wont look as if it has a 5" lift...just leveled, which I prefer.
May 18th, 2011, 06:22 AM
Liked 169 Times in 151 Posts
dont go higher than 2 1/2 " on the 'level kit' any higher puts way to much strain on the ball joints
and make sure you get an alignment
and that "trimming out" mentioned above, its done to the plastic air damn / lower valance from the inside
the tires tend to rub at full turn
just a little plastic needs to be removed, and no one will ever notice
May 18th, 2011, 06:54 AM
I have a 3 inch leveling kit... With just 265x70x17's...
35's on a 4wd.. Usually has some minor rubbing...
Well hell.. Looks like im in the f250..350 section.. Sorrya bout that lol
May 18th, 2011, 04:31 PM
Bobkyle2, don't worry, they are pretty much the same!
May 20th, 2011, 05:10 AM
Any rubbing I had was on the suspension...A Arms I'm thinkn.
Thread Tools |
Display Modes |
Linear Mode
(View-All)
Members who have read this thread : 20
ASwaff400
BEYTILL
BigBlue79
bobkyle2
Booba5185
ChrisM86
CrazyD
critterman
Dumontdana
jallen3521
Joe'Bronco
JSoko
NavBrat97
neidhartt
nine5flareside
Russo2
Scotts Black FX4
socorny45
TedC
topdogdad1
