Quantcast VIN Decoding - 2008 F-150/Mark LT - Ford Truck Club Forum
Old June 27th, 2011, 10:30 PM
DoubleDee's Avatar
Images: 669
Post VIN Decoding - 2008 F-150/Mark LT
This information comes direct from my 2008 Ford F-150, Mark LT Workshop Manual. The information in there covers F150 and Mark LT.
Your VIN is located in a couple places. One will be viewable from the outside of the vehicle, located at the bottom of the windshield on the drivers side. You have to look through the windshield to see it. The other place is located on the Vehicle Certification Label, which will be located on the B pillar (where the drivers door latches) or on the drivers door itself. This label also has certain codes at the bottom, and what the stock tires size were at time of build completion, what PSI to inflate to, what size the wheels are, and the weight rating of the axles.
Here is a sample VIN (17 digits): 1FT P F12 5 0 8 F A00001
First 3 digits represent the World Manufacturer Identifier
1FD - Ford Motor Company, USA, truck (incomplete vehicle)
1FT - Ford Motor Company, USA, truck (completed vehicle)
5LT – Ford Motor Company (Lincoln), USA, truck (completed vehicle)
Fourth digit represents the vehicle brake type and GVW code, may also id the vehicle safety restraint system.
All, with driver and front passenger air bags.
R – 6,001-7,000 lbs F-150
P – 7,001-8,000 lbs F-150/Mark LT
V – 8,001-8,500 lbs F-150
5-7 digits represent vehicle line, series, and body type
F02 – F-150, rear wheel drive (RWD), RCAB, 6.5 ft flareside
F04 – F-150, four wheel drive (4WD), RCAB, 6.5 ft flareside
F12 – F-150, RWD, RCAB, all bed lengths, styleside
F14 – F-150, 4WD, RCAB, all bed lengths, styleside
W02 – F-150, RWD, Crew Cab, 6.5 ft flareside
W04 – F-150, 4WD, Crew Cab, 6.5 ft flareside
W12 – F-150, RWD, Crew Cab, both bed lengths, styleside
W14 – F-150, 4WD, Crew Cab, both bed lengths, styleside
W16 – Mark LT, RWD, Crew Cab, 5.5 ft styleside or 6.5 ft
W18 – Mark LT, 4WD, Crew Cab, 5.5 ft styleside or 6.5 ft
X02 – F-150, RWD, SCAB, 6.5 ft flareside
X04 – F-150, 4WD, SCAB, 6.5 ft flareside
X12 – F-150, RWD, SCAB, all bed lengths, styleside
X14 – F-150, 4WD, SCAB, all bed lengths, styleside
Eighth digit represents engine displacement and number of cylinders.
2 – 4.2L OHV, V6, EFI (F-150)
5 – 5.4L, 3-valve, SOHC, V8, EFI (F-150/Mark LT)
W – 4.6L, SOHC, V8, EFI (F-150)
V – 5.4L, 3-valve, SOHC, V8, EFI, Flex Fuel (F-150)
Ninth digit represents a check digit.
Tenth digit represents the model year.
4 – 2004
5 – 2005
6 – 2006
7 – 2007
8 – 2008
Eleventh digit represents the assembly plant code.
F – Dearborn (Dearborn, Michigan) F-150/Mark LT
K – Kansas City (Claycomo, Missouri) F-150
The last six digits represents the vehicle build sequence and serial number.
A00001-F99999 – Ford F-150
J00001-L99999 – Lincoln Mark LT
Double(. Y .)Dee
SSG, TXARNG
How To Use The FTC Gallery
VIN Decoder
Big 3 Upgrade
Seat Removal
Interior Trim/Carpet Removal
ASwaff400 , DoubleDee , JSoko , Klitch , Shanehib , WilliamStali
Gott's Mod 2004-2008 DoubleDee Garage Talk: Shop Class 101 17 July 19th, 2011 01:15 PM
VIN Decoding - 1998 Model Year DoubleDee Garage Talk: Shop Class 101 1 June 28th, 2011 08:15 AM
93 mark III flareside 93MARKIII 1992-1996 Ford F150
5 March 9th, 2010 09:42 PM
Pri 2008 - new edelbrock pro port heads EdelbrockTV EdelbrockTV 0 February 8th, 2010 04:52 PM
SEMA 2007 - Get revved up for 2008! TRUCK U TRUCK U 0 February 3rd, 2010 01:40 AM
2008 , decoding , f150 or mark , vin
or any of their subsidiaries. Fordฎ is a registered trademark of the Ford Motor Company
