Quantcast How to Test a Manifold's Absolute Pressure Map Sensor - Ford Truck Club Forum
Old July 15th, 2011, 09:19 AM
Thumbs up How to Test a Manifold's Absolute Pressure Map Sensor
Test a Manifold's Absolute Pressure Map Sensor The manifold absolute pressure sensor, or MAP sensor, is generally used in place of the mass airflow sensor in an automobile. It preceded the mass airflow sensor and was much less efficient. The MAP sensor measures the pressure in the intake manifold through a vacuum. The more pressure, the lower the vacuum and the lower the voltage output. The lower the pressure, the higher the vacuum and the higher the voltage output signal. The mass airflow measures the volume of air moving into the manifold.
Things You'll Need
Voltmeter
1
Connect the voltmeter to the MAP sensor by connecting the black lead to a good ground and connecting the red lead to the center of the three wires in the MAP sensor's electrical connector.
2
Turn the ignition key on with the engine off. The voltage displayed on the voltmeter should be between 4.5 to 5 volts.
3
Start the engine and the voltage displayed should be .5 to 1.5 volts at sea level or close. The voltage will decrease as altitude increases. If the voltage differs greatly on either test, the MAP sensor is fried. Replace it.
Old February 14th, 2018, 03:16 PM
Bulldog74's Avatar
Bulldog74 Bulldog74 is offline
Hi JSoko,
I found your procedure on testing a MAP sensor.
I used this procedure on my 1994, F250 XLT 4X4 7.5l truck. The voltages are VREF is 5 volts, BP/MAP 2.5 volts and Signal Return is 11.7 volts.
The truck starts just fine, fires right off and runs, then after engine temp comes up rpm fluctuates and after a period of time it dies.
What I'm trying to diagnose is- when the engine comes up to temp the engine rpm fluctuates between 900-1200 rpm. It does this up and down until it stalls. I do see black smoke out the tailpipe.
I checked using a frequency setting on my DVOM at KOEF and I have 159hz and voltage at BP/MAP (center wire) is 2.5 volts. With engine on an up to temp (before rpm hunting) it registered 104 hz still 2.5 volts. What I didn't check was vacuum to frequency using a vacuum pump.
Have you had any experience with this type of symptom? Any direction is helpful.
Bulldog74
Old February 14th, 2018, 11:49 PM
Liked 113 Times in 109 Posts
Have you checked for OBD1/EEC codes?
Old February 15th, 2018, 02:27 PM
Bulldog74's Avatar
I haven't picked up an OBD-1 scanner yet.
After the last write up I checked the MAP sensor again for voltage at BP/MAP center position again. With KOEF it still has 2.5 volts connected (by back probing the connector) but when disconnected from the MAP sensor I do read 5 volts. Also, there's no check engine light. What I'm thinking is that whatever electrical component is in the map sensor is failing after vacuum build up takes place.
Old February 15th, 2018, 10:43 PM
Pick up a used map sensor from a junkyard cheap and throw it in there, see what happens.
harrison28 (April 2nd, 2018)
Old March 22nd, 2018, 04:54 PM
Alfa94_7.5_4x4's Avatar
Alfa94_7.5_4x4 Alfa94_7.5_4x4 is offline
Default Follow on Bulldog74
Bulldog74,
I am having the same issue as your right now with my Rig, I am on my third Map Sensor right now and the problem tends to arise when at operating temperature same symptoms as yours. Did you happen to have a solution yet?
Old April 2nd, 2018, 02:24 PM
Bulldog74's Avatar
Alfa94,
I finally got back to this issue and I purchased a new Map Sensor. And the way it looks that this is the first replacement of this sensor. The test I did found correct voltage in but not out. I didn't get a scanner yet but will. As for now the conditions are gone with the new Map Sensor.
Alfa94_7.5_4x4 , Booba5185 , Bulldog74 , DoubleDee , glc , harrison28 , HawaiianF150 , JSoko , Klitch , mucklife13 , nine5flareside , Russo2 , Stanw , vjsimone , whitesleeper
The Perfect Tire Pressure AutomotiveTV AutomotiveTV 2 July 6th, 2010 08:47 AM
Jet Mass Air Sensor Bates88 Garage Talk: Engine & Drivetrain 1 July 5th, 2010 08:45 AM
Testing a Ford 5.0L throttle position sensor BADSHOE BADSHOE Productions 0 March 14th, 2010 06:07 PM
Testing a 5.0L Ford Throttle Position Sensor Video BADSHOE BADSHOE Productions 1 January 5th, 2010 04:42 PM
Teen's beating death puts pressure on officials BigT67 General Discussion
10 September 29th, 2009 01:47 PM
absolute , manifold , map , pressure , sensor , test
