How to Change a Ford Cruise Control Switch - Ford Truck Club Forum
Old July 15th, 2011, 09:51 AM
Images: 616
Liked 169 Times in 151 Posts
Thumbs up How to Change a Ford Cruise Control Switch
The Ford cruise control switch is secured to the steering column with a simple retaining pin or clip (depending on the year of your Ford). The cruise control module monitors the Ford vehicle's speed and allows the driver to set the speed so that the vehicle maintains that set speed without any further input from the driver. Unfortunately, some Ford cruise control modules have been known to overheat and fail. When this happens, you need to replace the cruise control switch.
Things You'll Need
Paperclip
1
Verify, or turn, the cruise control switch to the "off" position.
2
Straighten out a paperclip and insert it into the small hole on the end of the cruise control switch.
3
Push the paperclip in as far as it will go. You should feel resistance. This is normal. The paperclip needs to push against the release tab on the inside of the switch. Push against the release tab while you pull the cruise control switch off the steering column.
4
Install the new cruise control switch by sliding it onto the steering column. Use the same orientation as the old switch during installation.
Old July 20th, 2011, 09:45 AM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
What years does this apply to?
Does it also apply to Ford cars?
Aren't the module and switch separated by the firewall?
Is this related to the recall on late 1990's early 2000's F150's cruise control issue that burned trucks to the ground?
Big T
Old July 20th, 2011, 11:55 AM
Images: 616
it applys to the years that the control was on the shifter and not the steering wheel/horn
Cars yes
the switch is in the steering column
its is the de-activation switch next to the brake booster that caused the fires
I copyed this from DoubleDee
Originally Posted by DoubleDee View Post
looking at the cruise control deactiviation switch, located by the brake master cylinder. There should be an electrical switch with 2 wires on the forward portion of the brake cylinder. They had a recall on these for certain years and you might want to check it out.
The reason for the recall, was because the switch leaked, and this would over heat the switch and cause a fire. So, pull the connector apart on top of the switch and see if there is brake fluid within the connector. If so, there's your short, and your cruise control will not turn on. This problem can cause a fire, even with the truck off. I think it cost me around $24.05 for the pigtail you see in the pic above to fix, and before I knew about the recall.
Old July 20th, 2011, 03:59 PM
BigT67's Avatar
Images: 262
My wife's car (2004 Taurus) has cruise control buttons on the steering wheel, and they used to work, but now not so much. Also, some times it will pick up speed when it should be coasting or slowing down....
I haven't even started to look into it yet.
Big T
ASwaff400 , AWBenoit , BigT67 , DoubleDee , grb , HiRoller , JimmieDean7 , JSoko , Mr Bronco , nine5flareside , Pjclaudet , polargeek , sims137 , Terry G. , Tmkone , tuckerrt1 , TurboAl , whitesleeper
How to Diagnose Ford Cruise Control JSoko Garage Talk: Shop Class 101 0 July 15th, 2011 09:47 AM
How Do I Tell if an Inertia Switch Is Activated? JSoko Garage Talk: Shop Class 101 0 July 15th, 2011 09:43 AM
How to Change the EGR on a 2000 Ford F-150 JSoko Garage Talk: Shop Class 101 0 July 15th, 2011 09:33 AM
How to Change the PVC Valve on a 1984 Ford F-150 JSoko Garage Talk: Shop Class 101 0 July 15th, 2011 09:27 AM
Ford 8.8 Rear Differential Fluid Change DIXIE FIX Garage Talk: Shop Class 101 0 April 1st, 2010 11:11 PM
change , control , cruise , ford , switch
