Quantcast Interior Trim/Carpet "Removal": '04-'08 - Ford Truck Club Forum
Old July 30th, 2011, 01:25 PM
DoubleDee's Avatar
Images: 669
Default Interior Trim/Carpet "Removal": '04-'08
Allright guys. This is those who need to get access behind the kick panels, under the thresholds/door sills and how to roll up the carpet/remove it. When I did the audio upgrade in my truck, I didn't remove the rear seat bottom, thus couldn't remove the carpet from the truck. If you need to remove the carpet from the truck 100%, then you'll need to remove all seat components and consoles. Then, you can move on to removing those little bit of extras that are holding the carpet down. I'll show those here. I didn't remove the B pillar trim pieces since the carpet can slide out from under, nor remove the trim pieces at the rear of the cab that are located behind the doors.
Seat Removal: '04-'08 Thread
Just an FYI, the whole dash, according to the owners manual, is considered the instrument panel. Thus, when it says to open the access panel for the fuse box located under the right hand side of the instrument panel, you'll know where to look. Also, a flow through console is one that has the gear selector located on it. It also has 2 vents at the back for the rear passengers. And it's "connected" to the instrument panel.
Double(. Y .)Dee
SSG, TXARNG
How To Use The FTC Gallery
VIN Decoder
Big 3 Upgrade
Seat Removal
Interior Trim/Carpet Removal
Old July 30th, 2011, 01:26 PM
DoubleDee's Avatar
Images: 669
Passenger Side Kick Panel
Once you pull up the sill plate, you can then remove the door weather stripping. Just start at the bottom where the ends meet, and slowly start pulling away from the body. It's held on by friction.
Now, the drivers side kick panel. Make sure to pull up the door sill and remove the weatherstripping first!
Then on to the thing under the instrument panel, in the middle. Some of you may have this, others may not (flow through consoles and trucks that have the floor shifter, and MAYBE regular cab trucks since there's no need to have venting going to the rear).
Now, you can start to remove the carpet / peel it back. Like I said above, if you want to remove the carpet 100% from the truck, you'll need to remove the rear seat bench. Once you get the carpet out of the way, this is what you'll have:
Flow through consoles won't have these, nor will regular cabs.
Double(. Y .)Dee
SSG, TXARNG
VIN Decoder
Big 3 Upgrade
Seat Removal
Old July 30th, 2011, 03:19 PM
good post, I like the way you do the particular details as in all your info
did'nt know about those air vents
time spent sitting next to an M-60 on a Slick, keeps me from enjoying the finer sounds in life
maybe I should be glad I dont have the need for a good stereo
cause that looks like a PITA
why did'nt you just use invisible wireless speakers LOL
975.4 , darwin333 , DoubleDee , HawaiianF150 , JSoko , memorylanelarry , RonaldFon , Scotts Black FX4 , southernhonkey , TPBull , tylerbotts , urthleafshomy , Willows Wind
Zappers 1993 Explorer Sport "Purple Haze" Pic heavy firezapper Ford Explorer 5 April 18th, 2010 12:11 PM
37" Toyo Open Country Tires Installed On 22" Rims Part 3 FordTruckClubTV FordTruckClubTV 11 February 11th, 2010 03:36 AM
37" Toyo Open Country Tires Installed On 22" Rims Part 2 FordTruckClubTV FordTruckClubTV 0 February 8th, 2010 04:05 PM
37" Toyo Open Country M/T Tires Installed On 22" Rims Part 1 FordTruckClubTV FordTruckClubTV 0 February 8th, 2010 04:05 PM
UPDATE: TV "pitchman" Mays had heart disease, no trauma RedHot150 General Discussion
4 June 29th, 2009 06:50 PM
0408 , interior , removal , trim or carpet
