Quantcast How to Convert a Four Pin Trailer Plug to a Seven Pin - Ford Truck Club Forum
Old August 28th, 2011, 01:58 PM
Images: 616
Liked 167 Times in 149 Posts
Lightbulb How to Convert a Four Pin Trailer Plug to a Seven Pin
Camping trailers may require a six- or seven-pin trailer electrical outlet. While some automobiles are wired to tow a trailer, not all trailers can be plugged into every electrical outlet. If you plan to tow a large trailer, the trailer plug will often contain six or seven electrical pins. The trailer electrical outlet that is factory-installed normally contains only four pins. Therefore, to tow a large trailer, it will be necessary to tap the electrical connections on the four-pin plug to install a seven-pin trailer connection.
Things You'll Need
Automobile with installed four-way trailer electrical outlet
Drill
Sheet metal screws
Screwdriver
Seven-way automotive-side wire harness
Electrical pliers
Crimp-type terminal splice connectors
1
Drill a hole under the rear bumper on the bottom left side of the automobile. Ensure that this hole is no more than 4 inches away from the installed four-way trailer electrical connector.
2
Place the frame of the seven-way harness so that the harness mounting hole lines up with the hole drilled in the bumper. Insert the screw into the mounting hole, and tighten the screw to hold the harness to the bumper.
3
Place a wire splice connector over the four-way outlet's green wire. Place the green wire from the seven-way harness into the splice connector, and crimp the terminal to join the wires.
4
Place a wire splice connector over the four-way outlet's yellow wire. Place the yellow wire from the seven-way harness into the splice connector, and crimp the wires together.
5
Place a wire splice connector over the four-way outlet's white wire. Place the white wire from the seven-way harness into the splice connector, and crimp the connector to make the electrical joint.
6
Place a wire splice connector over the four-way outlet's brown wire. Place the brown wire from the seven-way harness into the splice connector, and crimp the wires together
ASwaff400 , degored , F150GT , gizmo06360 , JSoko , polargeek , Russo2 , team1360
91 E350 convert to turbo Bathexpert Ford Vans 4 March 5th, 2011 10:08 PM
V60 Plug-in Hybrid is Three Cars in One AutomotiveTV AutomotiveTV 0 February 26th, 2011 03:44 AM
NEW '04-'08 Spark Plug; 4.6 & 5.4 3V JSoko 2004-2008 Ford F150
13 July 15th, 2010 09:59 PM
04-05 Spark Plug Problem 2004FX4F150 Garage Talk: Paint & Detailing 3 March 10th, 2010 03:35 PM
04 Plug change.... pete59edsel 2004-2008 Ford F150
30 October 5th, 2009 08:16 AM
convert , pin , plug , trailer
