Gear shift hung up in park - Ford Truck Club Forum
Old September 22nd, 2011, 03:39 PM
Colesburg Hood's Avatar
Colesburg Hood Colesburg Hood is offline
Default Gear shift hung up in park
Having problem with a 1989 F-350 dually I recently bought. Ever since I bought it I have been able to move gear shift (automatic) lever without pressing brake pedal. Now it is hung up in Park and won't come out no matter how hard you press brake pedal. Also, which might be related, key switch will not crank truck. Got any idea?
Old September 22nd, 2011, 03:45 PM
I don't know anything about the automatic lock out, but I do know the inside of that column quite well. It is an intricate combination of a push rod and some stuff.
My best advice would be to take off the covers and pull the ignition cylinder out (turn to the run position and use a small drift to push the pin underneath the cylinder and it pulls right out) and take a look at the stuff.
These are known for the rod snapping inside there and then you can't start the truck. If need be you can leave the covers off and start the truck by pushing the lower rod by hand.
I'd suggest just pulling those covers and see what it looks like in there, could just be gummed up. You may have to pull the wheel and turn signal switch, have to unscrew the rod and gently pull the white switch out.
That is if this is a tilt column...
Old September 22nd, 2011, 03:51 PM
Images: 616
Liked 169 Times in 151 Posts
before you start taking things apart, do a couple of checks
start by checking the brake light fuse, and all the other fuses in the cab & under the hood
could also be the brake light switch, this can be cheched with a mulit-meter
do you have the wheels turned to far to one side
try turning the key while you jiggle the steering wheel
Old November 8th, 2011, 12:06 PM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
Did this ever get resolved? I am curious about what the cause was....
Big T
Old November 8th, 2011, 02:19 PM
Images: 616
Greetings BigT
He has'nt been back since the day he posted this thread
Old November 8th, 2011, 07:39 PM
BigT67's Avatar
Images: 262
Well hopefully he'll reappear at some point.....
Big T
armoody , ASwaff400 , BigT67 , BLACK THUNDER , Bobbybe , cj3006 , Colesburg Hood , DoubleDee , Ford-f250 , HawaiianF150 , JSoko , Russo2 , whitesleeper
Gear oil. Russo2 Garage Talk: Paint & Detailing 1 June 10th, 2011 01:34 PM
shift linkage Jamesimm 1948-1983 Ford F100
2 November 3rd, 2010 03:53 PM
four wheel shift motor The-LI-Redneck 1992-1996 Ford Bronco
11 December 21st, 2009 10:05 PM
How To Center Shift Pointer Needle In F150 Instrument Cluster DIXIE FIX Garage Talk: Shop Class 101 5 November 28th, 2009 05:42 PM
Gear Ratios and Size Scotts Black FX4 2004-2008 Ford F150
22 July 18th, 2009 03:06 AM
gear , hung , park , shift
