Quantcast How to Change Power Steering Fluid - Ford Truck Club Forum
Old December 8th, 2011, 06:25 PM
Images: 616
Liked 167 Times in 149 Posts
Thumbs up How to Change Power Steering Fluid
Change power steering fluid quickly and easily and save the $55+ shop charge.
Simply siphon out the old and add fresh fluid.
There aren’t any test strips for power steering fluid, so you’ll have to rely on the manufacturer’s service recommendations or general rule-of-thumb (two years or 24,000 miles).
Use that turkey baster from Thanksgiving to remove the old power steering fluid or a syphon hose. Suck out all the fluid with the engine off.
Then refill the reservoir with fresh fluid.
Start the engine and let it run for about 15 seconds while turning the wheels a little each way.
Repeat the fluid swap procedure until you’ve used up 2 quarts.
NOTE: Never substitute a “universal” power steering fluid for the recommended type, and never add “miracle” additives or stop-leak products.
They can clog the fine mesh filter screens in your steering system and cause expensive failures.
Old December 8th, 2011, 11:48 PM
Good info! Thanks for the post!
Old December 9th, 2011, 12:02 AM
marmaduke's Avatar
marmaduke marmaduke is offline
Thanks, I will do my 2 vehicles sometime soon if its that easy.
A KICK IN THE ASS IS STILL A STEP FORWARD
Old December 9th, 2011, 12:34 AM
What are your thoughts on using atf versus power steering fluid.
I think just about every truck, at least the older ones, came from the factory with atf in there instead of power steering fluid. But I'm pretty sure the manual calls for using ps fluid.
And wheres the turn signal fluid thread?
Old December 9th, 2011, 05:15 AM
Images: 616
read the NOTE:again on first post
I may need to change the blinker fluid also but my manual says good for lifetime
Old December 9th, 2011, 10:06 PM
Liked 49 Times in 42 Posts
I use ATF when I fill mine back up, I used it in the '79. I've found when having a snow storm(earlier this year) don't forget to put the cap back on the PS Pump Resevoir, that crap got all over the underside of the hood and all over the inner fender so I had to refill'er.
Old December 10th, 2011, 07:55 PM
Images: 616
yes ATF is a manufacture recommended fluid
you can also find the recommended fluid stamped on the cap
Old December 10th, 2011, 08:12 PM
I wonder if we need to add a dummy disclaimer?
I have visions of a lost macaroon peeling the remnant parts of a deflated airbag off their face bouncing throughout my head....
Oh Well - at least at sometime down the future time line road, they will be able to add a little white lith grease somewhere in the steering column and hopefully around the turn signal area - only kidding folks ..........
BTW, Joey - Happy late B-Day!!
Old December 10th, 2011, 08:39 PM
I wish they had a way to add grease to the ignition actuator rod, my ignition cylinder is hard to turn when trying to start it, I went through hell in the summer just spraying WD-40 on the rod to lube it for summertime and changing the switch on the column and the cylinder..
Old December 10th, 2011, 10:13 PM
Images: 616
Y'all need to set the Bar
90f150xltcenturion , 91klunkr , A/Ox4 , BigBlue79 , Booba5185 , DoubleDee , HawaiianF150 , JSoko , Klitch , lanejesse85 , marmaduke , mike kellerman , Russo2 , wlshor
Power Steering (BOX) Klitch 1997-2003 Ford F150
18 March 23rd, 2012 01:11 PM
Eliminate power steering WORLDWITHIN@VERIZON.NET 1993-1997 Ford Ranger
41 January 9th, 2012 09:27 PM
trans fluid change Stewy 39 1997-2003 Ford F150
13 July 10th, 2011 10:53 AM
Time to change the transmission fluid Bates88 Garage Talk: Paint & Detailing 5 May 24th, 2011 06:50 AM
Ford 8.8 Rear Differential Fluid Change DIXIE FIX Garage Talk: Shop Class 101 0 April 1st, 2010 11:11 PM
change , fluid , power , steering
