Quantcast 1986 Bronco "Re"build thread. - Page 2 - Ford Truck Club Forum
Old March 12th, 2012, 07:35 PM
Images: 2025
Liked 40 Times in 35 Posts
All I've go left to do is tweek the passenger side door, and bolt the inner fenders back on.
So I've finally got crank windows and rust free fenders. Now I've just gotta get 31's.
How to Read Spark Plugs | Tuning with a Vacuum Gauge | How to use a Multimeter | 1988 F150 Exhaust Sound Clip | 9007 Bulb Conversion for 87-91's | How to Retrieve Trouble codes from OBD-1 trucks | 1987-1993 and 1994 Proper Plug Wire routing | 351m/400 Tips and Tricks | 351w R&R thread | Carbureted 302 Roller Cam Engine Build
When Christ was on earth, the dogwood grew
To a towering size with a lovely hue.
Its branches were strong and interwoven
And for Christ's cross its timbers were chosen
Being distressed at the use of the wood
Christ made a promise which still holds good:
"Not ever again shall the dogwood grow
To be large enough for a tree, and so
Slender and twisted it shall always be
With cross-shaped blossoms for all to see.
The petals shall have bloodstains marked brown
And in the blossom's center a thorny crown.
All who see it will think of Me,
Nailed to a cross from a dogwood tree.
Protected and cherished this tree shall be
A reflection to all of My agony."
Guns
Remington 700 ADL .270 Win
Remington "The Sportsman" 3 shot 16ga
Marlin Model 55 "Goose Gun" 12ga
T/C Hawken .45
T/C Thunderhawk .50
Enfield No4 Mk1*
Taurus PT1911AR .45 ACP
Hi-Point JCP .40 S&W
Hi-Standard "Sport King" Pump .22S, .22L, .22LR
New Haven 740T .22WMR
Mosin M1891/30
Savage 110 .270 Win
Truck
2004 Dodge Ram 1500 Quad Cab ST 4x4, 4.7, NV3500 5spd, Np241 T-Case, 9.25" Rear, 205mm HD Front Axle, Short Bed, Undercover® Tonneau Cover, Black Nerf Bars.
Old March 12th, 2012, 08:48 PM
Raleigh's Avatar
Raleigh Raleigh is offline
Images: 159
Nice straight body, now get some paint on it!
Dave
Old March 12th, 2012, 08:52 PM
JSoko JSoko is online now
Images: 514
Liked 99 Times in 83 Posts
what color did you decide to go with
Old March 12th, 2012, 09:14 PM
Images: 2025
Haven't decided yet, I know I want a tu-tone with white or silver and a blue, thinking like cobalt blue and silver, I gotta see if Sherwin Williams mixes car paint. I just got done taking the trim off, and priming the remaining rust, I've gotta cut the rust out of the tailgate also.
Guns
T/C Hawken .45
T/C Thunderhawk .50
Enfield No4 Mk1*
Mosin M1891/30
Savage 110 .270 Win
Truck
Old March 12th, 2012, 09:26 PM
Images: 359
Liked 22 Times in 18 Posts
Are you going to sand and redo the primer then..?
1990 F150XLTLariat. 300I6. M5OD. HURST! 3.55LS.
BDS six inch long arm lift. 36x16.50x15 Kevlar Fun country.
Old March 13th, 2012, 12:07 AM
Images: 2025
I have to, this was just to try and keep it from rusting faster than it was, and to get rid of the blehhhh blue that the 85 was painted. I gotta get some patch panels for the t-gate and some body filler for the rear wheel wells, I can't do the rear wheel well patches, might just take it to Maaco and have them fix the body.
Guns
T/C Hawken .45
T/C Thunderhawk .50
Enfield No4 Mk1*
Mosin M1891/30
Savage 110 .270 Win
Truck
  #17
Old March 13th, 2012, 01:16 AM
Ridgerunner's Avatar
Images: 53
Liked 4 Times in 4 Posts
Good Thread. If you get a chance go over to Mid Western parts on Lewis. There is a mid 90's FSB there and several trucks to get parts from.
  #18
Old March 13th, 2012, 11:00 AM
Images: 514
silver is a tough color to put on
have you looked a JC Whitney or LMC they both sell different parts of the fender for repair
http://www.jcwhitney.com/truck/body-...=d50227y1986j2
  #19
Old March 24th, 2012, 12:31 AM
Images: 2025
Well when I pull the engine to replace the pan gasket, the plans are as follows: I'm going to unbolt it from Torque Converter, unbolt the Starter, unbolt the Tranny from engine, cut the Exhaust(I'll 'splain why), unbolt the fan, shroud, radiator, drain coolant then pull the shroud and radiator, drain oil, unbolt the accessories. When I pull it, I'm going to leave the mounts on the engine, and just unbolt the towers from the perch's(I guess is what they are called), the reason for the exhaust cutting is I'm going to run headers(finally), while it's out I'm going to degrease it and give it a proper paint job in a darker blue, I'm also going to clean the engine bay and the crossmember and axle's of the nasty oil. Afterwards it will get a tune-up, and either Quaker State or Castrol GTX oil. I've also got a newer radiator to put in it to get rid of my leaky one.
Guns
T/C Hawken .45
T/C Thunderhawk .50
Enfield No4 Mk1*
Mosin M1891/30
Savage 110 .270 Win
Truck
  #20
Old March 24th, 2012, 12:39 AM
Images: 53
That is a great plan. Ever think about a electric fan?
ASwaff400 , BigBlue79 , BigRob , bikertrash3531 , Booba5185 , chapter , DoubleDee , Ford 005 , Gino11 , JSoko , Klitch , Petey D , Raleigh , Ridgerunner , Russo2 , skatebowd , WORLDWITHIN@VERIZON.NET
C-LIST 82 - 96 F150/Bronco 4" Lift - CHEAP nine5flareside General Discussion
1 July 12th, 2010 09:33 AM
Zappers 1993 Explorer Sport "Purple Haze" Pic heavy firezapper Ford Explorer 5 April 18th, 2010 12:11 PM
37" Toyo Open Country Tires Installed On 22" Rims Part 3 FordTruckClubTV FordTruckClubTV 11 February 11th, 2010 03:36 AM
37" Toyo Open Country Tires Installed On 22" Rims Part 2 FordTruckClubTV FordTruckClubTV 0 February 8th, 2010 04:05 PM
37" Toyo Open Country M/T Tires Installed On 22" Rims Part 1 FordTruckClubTV FordTruckClubTV 0 February 8th, 2010 04:05 PM
1986 , bronco , rebuild , thread
Powered by vBulletin® Version 3.8.6 Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
