Quantcast How to remove a wiper motor. - Ford Truck Club Forum
Old January 3rd, 2012, 09:08 PM
Default How to remove a wiper motor.
Start off by marking your wipers left and right, pull em off and set them aside.
Next, remove the screws on the top side of the cowl panel, mine were all philips head, mis matched though so obviously they've been out before.
Next for safety's sake unhook your battery's negative cable. Then go up and unplug wires from the motor, the number of plugs will vary from truck to truck.
Now get that screw driver again and take out the couple of screws that hold the cowl on under the hood. You will also have to unplug the hose for your windhsield fluid "pissers". You may or may not have to remove the antenna, since mine doesn't actually unplug from this end, and tearing out the radio wasn't worth it, I just hung it on the side of the truck
I would not suggest doing this if you care about your trucks paint..
Now take off that there plate, just a couple more screws to keep track off.
With that out of the way crawl up on the hood and find the linkage
I tried that bolt first, that got me no where. I went for the clip and pulled the individual linkage pieces off.
Now you can take off the actual mounting bolts and pull the motor.
Whenever you put everything back together make sure that the hose for the wiper fluid is back on securely and get all wires plugged back up tightly and any ground wires are hooked up.
Old January 3rd, 2012, 11:44 PM
ground wires Yes
Aliciawrick , BigBlue79 , Booba5185 , chesster51 , Frankkip , joe250 , JSoko , Ronnietah , Russo2 , Tr00b , WilliamStali
Pedal assembly is fubar! Wiper motor is too!! Russo2 1973-1991 Ford F150
11 January 5th, 2012 10:15 PM
wiper woes ewalton9 1999-2007 Ford F250 | F350
1 December 24th, 2011 04:28 PM
2000 F150 Windshield wiper problem hvykvy951 1997-2003 Ford F150
2 June 11th, 2011 07:39 AM
Weird Wiper Problem (2008) TedC 2004-2008 Ford F150
9 February 12th, 2010 09:53 AM
Windshield wiper motor remove and replace BigT67 1997-2003 Ford F150
6 September 4th, 2009 01:07 AM
motor , remove , wiper
