Quantcast How to Clean the EGR Valve - Ford Truck Club Forum
Old January 4th, 2012, 02:37 PM
Images: 616
Liked 169 Times in 151 Posts
Arrow How to Clean the EGR Valve
How EGR Valve Cleaning Can Stop Stalling and Idling Problems
Get that new-car purr back again
Rough idle? A good dousing with throttle body cleaner may be enough to restore your EGR valve to near-mint condition, transforming a harsh idle into a soothing hum .
Idling and stalling problems can really add stress to your daily commute. The most common culprit is carbon buildup on the throttle body, exhaust gas recirculation (EGR) valve and idle air control (IAC) valve. I will tell you how to clean an EGR valve. This simple procedure can often bring an EGR valve back from the dead and restore a smooth idle. If the cleaning doesn’t work, you’ll have to replace the valve .
Refer to a shop manual to find the location of your EGR valve. If it’s fairly accessible, stop at an auto parts store and buy a new EGR gasket, a spray can of throttle body cleaner, and rust penetrant. Spray the EGR retaining bolts with rust penetrant and let them sit while you disconnect the electrical and vacuum lines from the valve (label the vacuum lines so you know which ports they came from). Then remove the retaining bolts and lift the EGR valve out.
Place the valve on a bed of paper towels and tilt it so the cleaning solvent won’t drain into the electric solenoid or vacuum motor , which operates the metering rod—the solvent can damage those components. Spray the port and metering rod until they’re clean (Protect your eyes ). Once the parts are clean, check for smooth metering rod operation by forcing the rod in and out of the port with a screwdriver . It should slide smoothly and close completely in the port. If not, apply solvent to a cotton swab and clean the shaft and port.
Check the passage under the EGR valve to see if it’s clogged with carbon. If it is, gently chip out the carbon with a small screwdriver and vacuum it out with a shop vacuum. Then reinstall the EGR valve using the new gasket
Remove and clean the valve
1: Spray the valve
Hold the EGR valve so the cleaning spray drips away from the electric solenoid and vacuum motor. Continue spraying until the parts are free of carbon buildup.
2: Check the metering rod
Check for smooth operation of the metering rod by pushing it in and out with a screwdriver. If it slides roughly, clean it with a cotton ball or swab soaked in cleaner.
3: Gasket
Replace the EGR gasket as part of the cleaning procedure.
NOTE: the 5.4, 3 valve engine DOES NOT have an EGR valve due to the Variable Valve Timing
97F350BH , alucrazy , Bluegillfisher , havefordwilltravel , JSoko , Matt Casserly , polargeek , Red91 , rgchak , Russo2 , TFH Kane , topncc , tylerbotts , wicat3 , zangeif86
How To Clean Battery Terminals JSoko Garage Talk: Shop Class 101 4 October 26th, 2011 10:42 PM
How To Clean Oil Off Your Driveway JSoko Garage Talk: Shop Class 101 0 August 26th, 2011 09:22 PM
How to Clean an Exhaust Manifold Gearz Gearz 1 June 28th, 2010 11:16 AM
How-To Clean Car Battery Terminals MOTORZ TV MOTORZ TV 0 February 15th, 2010 05:23 PM
How-To Clean Car Battery Terminals MOTORZ TV MOTORZ TV 0 February 11th, 2010 03:01 AM
clean , egr , valve
