January 8th, 2012, 09:03 PM
Ken - Here ya go! Try these on for size!
Would not use the glass fuel filter!
January 8th, 2012, 09:45 PM
Liked 40 Times in 35 Posts
I followed another guy's 300 build in his 1981 Bronco(abandonedbronco on FSB) and he used the Offy intake and a Holley 390cfm carb, IIRC he had to make a special bracket to get the throttle to work right.
As it stands now, dad won't let me get anything along those lines^ H, beside's I love those little one barrel carbs, you should've seen the one I had on the 86 I traded for this bronco, it had an Industrial 300(I kicked myself in the ass for getting rid of it) I took the carb off and rebuilt it and before I put it back together I had it tumble polished, so there is was a bright ass carburetor on that 300, I used to get all kinds of looks when I'd pop the hood, I may just have the samething done on this one..
How to Read Spark Plugs | Tuning with a Vacuum Gauge | How to use a Multimeter | 1988 F150 Exhaust Sound Clip | 9007 Bulb Conversion for 87-91's | How to Retrieve Trouble codes from OBD-1 trucks | 1987-1993 and 1994 Proper Plug Wire routing | 351m/400 Tips and Tricks | 351w R&R thread | Carbureted 302 Roller Cam Engine Build
When Christ was on earth, the dogwood grew
To a towering size with a lovely hue.
Its branches were strong and interwoven
And for Christ's cross its timbers were chosen
Being distressed at the use of the wood
Christ made a promise which still holds good:
"Not ever again shall the dogwood grow
To be large enough for a tree, and so
Slender and twisted it shall always be
With cross-shaped blossoms for all to see.
The petals shall have bloodstains marked brown
And in the blossom's center a thorny crown.
All who see it will think of Me,
Nailed to a cross from a dogwood tree.
Protected and cherished this tree shall be
A reflection to all of My agony."
Guns
Remington 700 ADL .270 Win
Remington "The Sportsman" 3 shot 16ga
Marlin Model 55 "Goose Gun" 12ga
T/C Hawken .45
T/C Thunderhawk .50
Enfield No4 Mk1*
Taurus PT1911AR .45 ACP
Hi-Point JCP .40 S&W
Hi-Standard "Sport King" Pump .22S, .22L, .22LR
New Haven 740T .22WMR
Mosin M1891/30
Savage 110 .270 Win
Truck
2004 Dodge Ram 1500 Quad Cab ST 4x4, 4.7, NV3500 5spd, Np241 T-Case, 9.25" Rear, 205mm HD Front Axle, Short Bed, Undercover® Tonneau Cover, Black Nerf Bars.
January 8th, 2012, 09:52 PM
Liked 22 Times in 18 Posts
That stuff comes at a hefftttyyy price. Headers alone are 3-500.
If you really wanna see prices though, go to clifford. http://www.cliffordperformance.net/index.html
I have heard that since the old man died, their stuff isn't as good as it used to be and is over priced.
Anywho, mpg. Just filled up on my way back to school.
Uncorrected : 193 /13 gallons = 14.84 mpg
Corrected: 219 /13 gallons = 16.84 mpg
I am not nice to my truck, I don't take it easy light to light etc, so I have no doubt your old 88 got 18 mpg, but with a carb'd motor I just don't know.
Only one way to find out, eh?
Oh and for tire corrections I used this site.
http://www.1010tires.com/TireSizeCal...?action=submit
You will see that the speedometer difference is 7.26%
And tire size difference is 6.79%
January 8th, 2012, 10:09 PM
Russo that whole kit was $850(ish) but that said it was a complete kit including headers, intake and the carb
January 9th, 2012, 12:04 PM
Thanks for the help Hawaiian, I can't get a header or 4bbl intake(dad almost literally crapped himself when I mentioned it) so I think this is how it is going to be:
Things to be done to the 300 once I buy one: Swapping the single piece "Log" style exhaust manifold(that restrict's exhaust) in favor of the 2 piece EFI's which flow better, Carburetor rebuild, de-greasing the engine, replacing all gaskets before putting it in the bronco, paint(still undecided on the color, I'm leaning towards Dark Blue or Red), Tune-up(no sixlitre until I figure out how well the engine runs). I'll think of something else to do and add it to the list.
Guns
T/C Hawken .45
T/C Thunderhawk .50
Enfield No4 Mk1*
Mosin M1891/30
Savage 110 .270 Win
Truck
January 9th, 2012, 08:51 PM
Liked 99 Times in 83 Posts
once had a Falcon with a 170 & 4bbl three speed, headers, fast...
January 9th, 2012, 10:39 PM
Originally Posted by big_blue79
So I've decided for the Bronco on a 300 I6 engine swap before the engine goes in I'm going to pretty it up a little bit and do the exhaust modification to it. I figured I'd start this thread for the chronicle of when it begins.
These are in no particular order:
The plans are to buy a 300 clean it up and go over the engine and install all new gaskets(IE: Head gasket, Valve Cover Gasket, oil pan gasket), pull the one piece exhaust manifold and swap on the 2 piece EFI's(for better exhaust flow), probably do a carburetor rebuild(eazy peazy lemon squeezy), tune-up, oil and filter change, paint the engine..
Then I'm going to get 4x4 300 engine mounts, a 300 flexplate(for my c6), warranty my starter so I can get another good one, pull the 351w out and clean it up, while it is still in the Bronco I'm going to drain the oil, break the oil pan bolts loose, pull it, take off the pan, clean the pan off and out and paint it, scrape the old gasket off, put on a new one piece gasket(this'll be the last gasket it needs), reinstall the pan, then degrease the engine and paint it, I'm still undecided if I'm going to sell it or keep it I'm leaning towards keeping it(be cause it is such a good running engine).
I'll probably be asked "Why do you wanna pull the 351w and swap in a 300?" well my answer is, I'm looking for better gas mileage and I've got a running bet going that I could make the Bronco hit 20 MPG's even being a 4x4. I may even go for the Sixlitre Tune-up as they can be done on the 300(just don't know if I wanna pony up for the expensive $h!+ that the tune-up calls for.
NICE EDGAR ALLAN PHILOSOPHY. THE 300 IS A GOOD CHOICE. IT HAS 7 MAIN BEARINGS, HIGH TORQUE AND A REP FOR RELIABILITY. 6 MONS AGO I ALMOST BOUGHT A APPROX. 1985 300 CU. IN F-150 WITH A STICK AND O/D FOR $1700. i WISH I HAD BOUGHT IT, TIMING WAS BAD -LIFE, NOT IGNITION. I PURCHASED A RANGER INSTEAD. I IMAGINE THAT I COULD HAVE GOTTEN 20 MPG OUT OF THAT 2 WHEEL DRIVE F-150. LIGHTER THAN A BRONCO WITH MORE GLASS AND 4X4. YOU CAN ALWAYS TRADE OFF ACCELERATION FOR MPG'S BY INSTALLING A LOWER REAR END IN A 2 WHEEL DRIVE.BUT, AND IM UNSURE HERE, YOU MAY NEED TO CHANGE YOUR FRONT DRIVE TO COMPENSATE ? GOOD LUCK , VERY INTERESTING, I WILL HOPE TO CONTINUE READING ABOUT IT
I PUT A AMC V-8 INTO A OVERHEAD CAM 6 JEEP WAGONEER ONCE. THAT WAS PRETTY SIMPLE. MANY YRS AGO.
January 10th, 2012, 08:29 AM
if you have a 4X4 and you change the rear gear, if you plan on useing the front the front gear has to match the rear
January 10th, 2012, 11:35 AM
The poem in my signature was one of the last Edgar Allen Poe did, he wrote it 1849 during the California gold rush, James Caan recited it in one of my favorite John Wayne movies El Dorado, and the opening song of the movie was a version of the poem.
Guns
T/C Hawken .45
T/C Thunderhawk .50
Enfield No4 Mk1*
Mosin M1891/30
Savage 110 .270 Win
Truck
January 10th, 2012, 11:42 PM
Well, dad decided(as usual) to go ahead and pay $390 to have the pan gasket replaced at a shop in town, I'm going out tomorrow to check out a 1988 F150 S/C with a 5.0 and Auto tranny, if I buy it pics are to come in a new thread, this one is closed(for the time being)
Guns
T/C Hawken .45
T/C Thunderhawk .50
Enfield No4 Mk1*
Mosin M1891/30
Savage 110 .270 Win
Truck
| Thread Tools |
| Display Modes |
Linear Mode
(View-All)
Members who have read this thread : 12
BigBlue79
Booba5185
F150GT
gooy1129
HawaiianF150
herbz
JSoko
Klitch
nine5flareside
Russo2
vanman
WORLDWITHIN@VERIZON.NET
