Quantcast Reading Spark Plugs - Ford Truck Club Forum
Old January 7th, 2012, 11:54 PM
Default Reading Spark Plugs
Being able to "read" a spark plug can be a valuable tuning aid. By examining the insulator firing nose color, an experienced engine tuner can determine a great deal about the engine's overall operating condition.
In general, a light tan/gray color tells you that the spark plug is operating at optimum temperature and that the engine is in good condition. Dark coloring, such as heavy black wet or dry deposits can indicate an overly-rich condition, too cold a heat range spark plug, a possible vacuum leak, low compression, overly retarded timing or too large a plug gap.
If the deposits are wet, it can be an indication of a breached head gasket, poor oil control from ring or valve train problems or an extremely rich condition - depending on the nature of the liquid present at the firing tip.
Signs of fouling or excessive heat must be traced quickly to prevent further deterioration of performance and possible engine damage.
Heat Range Reference:
NGK - The larger the number after the dash the colder the plug is. Example a R5671A-7 (a good street/strip plug) is a cold plug where a R5671A-10 is a very
cold plug used for large 400hp and up nitrous and other power adder applications).
Autolite - The larger the last digit in the part number, the hotter the plug is.
Example a AR3935 (good street/strip plug) is hotter than a AR3932 plug which is very cold used for lots of nitrous.
Champion - Typically Champion numbers in the same series the larger the number the hotter the plug.
Normal Life:
A worn spark plug not only wastes fuel but also strains the whole ignition system because the expanded gap (due to erosion) requires higher voltages. Normal rates of gap growth are as follows: (0.000126~0.00252 inches/1,000 miles).
Normal Condition:
An engine's condition can be judged by the appearance of the spark plug's firing end. If the firing end of a spark plug is brown or light gray, the condition can be judged to be good and the spark plug is functioning optimally.
Dry and Wet Fouling:
Although there are many different cases, if the insulation resistance between the center electrode and the shell is over 10 ohms, the engine can be started normally. If the insulation resistance drops to 0 ohms, the firing end is fouled by either wet or dry carbon.
Overheating:
When a spark plug overheats, deposits that have accumulated on the insulator tip melt and give the insulator tip a glazed or glossy appearance.
Deposits:
The accumulation of deposits on the firing end is influenced by oil leakage, fuel quality and the engine's operating duration.
Lead Fouling:
Lead fouling usually appears as yellowish brown deposits on the insulator nose. This can not be detected by a resistance tester at room temperature. Lead compounds combine at different temperatures. Those formed at 370-470°C (700-790°F) having the greatest influence on lead resistance.
Breakage:
Breakage is usually caused by thermal expansion and thermal shock due to sudden heating or cooling.
Abnormal Erosion:
Abnormal electrode erosion is caused by the effects of corrosion, oxidation and reaction with lead - all resulting in abnormal gap growth.
Erosion, Corrosion and Oxidation:
The material of the electrodes has oxidized, and when the oxidation is heavy it will be green on the surface. The surface of the electrodes are also fretted and rough.
Lead Erosion:
Lead erosion is caused by lead compounds in the gasoline which react chemically with the material of the electrodes (nickel alloy) as high temperatures; crystal of nickel alloy fall off because of the lead compounds permeating and separating the grain boundary of the nickel alloy. Typical lead erosion causes the surface of the ground electrode to become thinner, and the tip of the electrode looks as if it has been chipped.
Oil Fouled
Oil Fouled
Carbon Fouled
Too Cold
Too Cold
Cold or Rich but OK
Cold or Rich but OK
Cold or Rich but OK
OK
OK
OK
OK
Better
Best
Better
Good
Good
Good
OK
OK
Kinda hot but OK
Hot or Lean, Questionable
Too hot or lean, Pre-ignition Range
HawaiianF150 (January 8th, 2012)
Old January 8th, 2012, 01:33 AM
Plug breakage can also caused by being in too much of a hurry to think about what your doing.
Especially true when (re-) installing... little bit of anti-sieze goes along way with the right amount torque
Old January 8th, 2012, 11:44 AM
No Anti-Seize for the threads on the
4.6L 3V, 5.4L 3V, 6.8L 3V
see the TSB http://www.etoolcart.com/06152.pdf
http://www.saac-mcr.com/main/2008_TS...park_Plugs.pdf
and forget the 'Rotunda Tool' they break; get a 'Lisle Plug Remover' http://www.denlorstools.com/home/dt1...65600_alt.html
Old January 8th, 2012, 03:19 PM
Big J - On that TSB - check pages 2, 3, 5, & 10 for the 2004-2008 model years with 4.6L 3V /5.4L 3V / 6.8L 3V engines.
"NEW PLUGS SHOULD BE INSTALLED USING A FILM COATING OF MOTORCRAFT HIGH TEMPERATURE NICKEL ANTI-SEIZE LUBRICANT
ON THE GROUND ELECTRODE SHIELD. DO NOT COAT THE ELECTRODE STRAP."
At least they are chasing the spark plug well threads at the same time they are using the tap to 'catch' all the busted porcelain debris with grease.
Most of us would rechase the well threads again after all the debris is verified to be removed and clean. Most likely not a real world action for a stealership's tech mech to do unless it was his or a friend's motor.
I have no faith and lots of doubt in stealership mech quality or that they have real pride in their workmanship ... Not even close to piss cool fuzzy feeling!
Old January 8th, 2012, 03:26 PM
there were 2 TSB's
the first says no anti-seize on the threads only the electrode shield
the other does not mention the threads
ANTI-SEIZE LUBRICANT (XL-2) ON THE GROUND
ELECTRODE SHIELD OF THE NEW SPARK PLUG
(FIGURE 7). DO NOT COAT THE ELECTRODE
STRAP OR THE PLUG WILL MISFIRE.
PLUGS SHOULD BE INSTALLED WITH NO
LUBRICANT ON THE THREADS AND TORQUED
TO SPECIFICATION, 25 LB-FT (34 N•m).
Figure 7 - Article 06-15-2
Old January 8th, 2012, 03:50 PM
Sounds like the blind leading the blind with different directions - no wonder I have no faith in workmanship. Thier leadership cant even get the TSB's clear.
How much you wanna bet some tech does coat the threads and the shield?
Old January 8th, 2012, 04:09 PM
not sure why to coat or not coat the threads
steel threads aluminum head use anti-seize
use anti-seize and over torque plugs
anyway the threads are not the issue on the 3 valve engines its the carbon build-up on the electrode shield
Old January 8th, 2012, 08:40 PM
If we're talking generalities about regular thread, bolts and such...
We both know that it is always best to correctly use the proper type of Anti-seize where temperature, pressure and elemental exposure factors (i.e., application, wind, water, chemical reactives, etc...) are introduced.
It protects as it allows easy assembly and disassembly and can ensure proper torque.
What was that old saying about teaching someone how to learn?
The hardest thing about learning - is learning to listen.
Old January 26th, 2012, 03:55 PM
WORLDWITHIN@VERIZON.NET's Avatar
WORLDWITHIN@VERIZON.NET WORLDWITHIN@VERIZON.NET is offline
I agree with this statement and about most all professional. They have the experience and knowledge to do good work. But, they are forced to fight the clock to provide large middleman profit (the fat cats ). Plus they can't be expected to love other peoples rides like the people on this forum tend to with their own. Im not a fan of home a/c repairmen or construction workers or even electricians.
However, i do like the entrance standards and continuing classes that some pro societies require. It helps to have the knowledge.but, how to have profits without greedy excessive profits ???
Old February 23rd, 2012, 09:58 AM
I'm updating this, I have added a chart to the original post, check it out and tell me what you think
(View-All Members who have read this thread : 28
90f150xltcenturion , audioface , badiggs , barrett_s , BigBlue79 , bikertrash3531 , Booba5185 , countrytruck , DON CHILDS , DoubleDee , duke daddy , goldman , GrassRoots150 , Groundpounder , HawaiianF150 , JSoko , Klitch , lanejesse85 , Moore1991bronco , nine5flareside , Raleigh , Rudystruck , Russo2 , Scuba steve , skatebowd , Ted94 , wicat3 , WORLDWITHIN@VERIZON.NET
Spark Plugs 5.8L BigBlue79 1980-1986 Ford Bronco
11 November 1st, 2011 06:21 PM
E3 Spark Plugs In Performance Engines Gearz Gearz 0 October 1st, 2011 04:24 AM
New spark plugs screwon23s 1997-2003 Ford F150
10 July 31st, 2011 08:48 PM
E3 Spark Plugs Gearz Gearz 0 March 23rd, 2011 04:11 PM
Which Spark Plugs? 2004FX4F150 2004-2008 Ford F150
4 December 11th, 2009 09:14 PM
plugs , reading , spark
