Quantcast Swap 1998 $x4 Front axle to 1997 4x$ - Ford Truck Club Forum
Old January 27th, 2012, 11:38 AM
HARLEY589's Avatar
HARLEY589 HARLEY589 is offline
Default Swap 1998 $x4 Front axle to 1997 4x$
[/SIZE] Well i made it to the Posting area.. I would like to know how many problems i will run into by switching the 2- axles.. As you guys know.. the rebuild on the front ends are alot of work.. which i don't mind.. but i came across a great deal ($200.00) for the complete axle set up ,from a 1998 4x4.. I will decribe all details.. The truck i have is a 1997 F350 4x4 Daully 7.3 Turbo Diesel. It was a Former Town Highway dump truck.with a 9ft minute man plow.. This put a beating on the bearings and hubs over the years.as to the weight. The trucks Vin is 1FDKF38F6VEA56130 , GVWR 14,000. The front axle is an Dana 60 straight axle.(093) 4.10 gears (189S) { ID Tag was missing} Ball joint, Leaf spring,Daully Hubs.. Which i think this is an excellent Front axle.. I took the rear axle tag for Id for the gears. ( 10.10.26K28) The Axle i want to use is out of an F350 Super Duty, Dana 60-70 4x4 straight axle ,ball joint. with 4.10 gears. Its part no, is 610655-2 date 0/8 27/ 1998 13:09 4.10 other no. F81A-3002-Aym..It also has the wheel adapters. Question is.. Will the axle hold this weight of my truck ? Mount up the same leaf springs, and steering.. Will it Swap.. Whats Parts will i need.. I just found out the wheel mounts (pattern) are different ! Any Help would be GREAT.. Thanks Guys ! FORD 4 x$ TRUCKS are TUFF !!
Old February 1st, 2012, 12:56 PM
HARLEY589's Avatar
Any help with this would be great..
Old February 1st, 2012, 01:46 PM
roughrider78's Avatar
roughrider78 roughrider78 is offline
Images: 2
how r your old leaf's. do u have the hole frontend will it just bolt up to if it will and the steering link is the same
but the axle sould be floting and if thay r all u have to do is take your old front end axle out and put thim in your new frontend
Old February 2nd, 2012, 11:40 AM
HARLEY589's Avatar
Hi Rough rider ~ Thanks much for the reply.. Yes your right about leaf spring mount.. I haven't took it apart,because i think i might hang the truck up in the middle of winter.. I guess i won't know until everything is out.. This is why i posted it.. I just wasnted to get all my nuts and bolts toghewther before i started this.. and then having more problems down the road.. Both trucks are the leaf spring, 4x4 balljoints, same gearing.. Its out of a 98 F350 super duty with adapters going on a 1997 daully F350. I thought the 60 dana and the 70 dana was the size of the ring gear ?? Thanks for checking this out.. Talk later.. Keep driving sideways.. Its Fun..
ASwaff400 , azfordman , Booba5185 , catmechanic07 , HARLEY589 , herbz , JSoko , Klitch , Lostin90s , roughrider78 , Russo2 , tylerbotts , whitesleeper
front axle swaP 1stockpstroke 1992-1997 Ford F250 | F350
9 August 16th, 2014 05:39 PM
1997 F350 4x4 Front Axle Swap to 1998 4x4 front axle HARLEY589 New Member Introductions 13 January 27th, 2012 10:52 AM
solid axle swap The-LI-Redneck Garage Talk: Solid Axle Swaps 12 August 30th, 2010 12:00 PM
Best axle for your swap, and how to identify it. DIXIE FIX Garage Talk: Brakes & Suspension 15 March 16th, 2010 07:51 AM
$x4 , 1997 , 1998 , 4x$ , axle , front , swap
