Quantcast 2000 F250 haunting - Ford Truck Club Forum
Old March 5th, 2012, 12:58 PM
Cothrom's Avatar
Cothrom Cothrom is offline
Images: 3
Unhappy 2000 F250 haunting
Have a mysterious problem with my Superduty F250 5.4 4X4 Auto that is pretty wild but probably an overlooked simple thing.
Runs and drives good, but for no "apparent" reason will start skipping and lose power and then die, no start. Turning the key on, at this time fuel pump doesn't cycle, no noise. When I check inside fuse/relay box, all seems ok, and shaking around under dash all of a sudden pump kicks back on and away it goes. I havn't plugged in a code reader yet and suppose that will be my next step. Was wondering if any owners have had the "mystery die out" happen?
Any info would be appreciated
Old March 5th, 2012, 01:03 PM
Im not sure if your year model has one
but there is a fuel switch located around the glove box that may be bad
have you checked the manual
Old March 5th, 2012, 01:52 PM
Sounds like a bad fuel pump to me.
Old March 5th, 2012, 06:09 PM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
I had a similar problem with a 2000 F150 and it turned out to be the fuel pressure regulator. The fuel pressure was rising and falling as the regulator was failing and the engine would sputter and cough, or just die, and then would run fine for a while before doing it again.
Big T
ashleyroachclip , BigT67 , Cothrom , DoubleDee , JSoko , nine5flareside , Russo2 , whitesleeper
Fathers 2000 PSD Klitch 1999-2007 Ford F250 | F350
6 November 15th, 2011 11:32 PM
1963 Ford 2000 JSoko Ford's Not Listed 4 September 25th, 2011 08:42 PM
How to Change the EGR on a 2000 Ford F-150 JSoko Garage Talk: Shop Class 101 0 July 15th, 2011 09:33 AM
2000 f150 3rd member * Terry G. 1997-2003 Ford F150
7 June 16th, 2011 08:55 AM
2000 F150 Windshield wiper problem hvykvy951 1997-2003 Ford F150
2 June 11th, 2011 07:39 AM
2000 , f250 , haunting
