Quantcast How To: Replace Fuel Filter (04-08 F150) - Ford Truck Club Forum
Old May 11th, 2012, 11:32 AM
DoubleDee's Avatar
Images: 669
Exclamation How To: Replace Fuel Filter (04-08 F150)
So, the maintenace manual for the truck says the fuel filter gets replaced at 30K mile intervals. So, for my first filter chance, I went with Motorcraft brand. I think I'll go Wix or see if I can get the Motocraft brand from O'Reillys.
The process is pretty simple. The only specialty tool you'll need is a fuel line disconnect tool.
Step 1 Disconnect electrical connector:
Step 2 Relieve fuel system pressure:
Start the truck, and let it stall out. Start the truck a couple more times to ensure you've relieved as much pressure out of the system. Book says to let the starter run for about 5 seconds.
*Note, with my truck, it has an electronic, computer controlled system to say when the starter shuts off. Releasing the key from Start to Run will not shut the starter off. The computer "tells" the starter to shut off when the engine starts. You have to manually turn the key to OFF.
Step 3 Disconnect Fuel Lines
This is when you'll know that you've relieved pressure or not. I suggest using some sort of catch container that you can put up towards the coupling as you're disconnecting them. This will catch whatever drains out of the line by gravity, and if the pressure wasn't relieved, will keep the fuel from spraying everywhere.
Step 4 Remove/Replace Fuel Filter
There's not much to add. Just reverse procedure to install. Just make sure the couplings are completely attached to the filter. You should hear a click when you push the couplings on. Once you're done, and everything is back to what it looked like before you started, you can start the truck and check for leaks. Remember, the truck might not start right away. Prime/pressurize the fuel line by turning to the key to Run, letting the fuel pump run it's cycle, then turn the key to Off. Do this a couple times. Then start the truck. It should start almost right away.
Here's what I poured out of my fuel filter:
And this is only after 29,700 miles!
Filters are preventive maintenance. Some say, "If it ain't broke, don't fix it!" Well... a $25 filter (I bought it from the parts counter at the stealership, I don't want to talk about it) beats replacing the fuel pump, clogged injectors, bad gas mileage, and whatever else that can result from a clogged filter.
Depending on if you bought your truck new or used, this could be the most expensive investment (2nd if you bought a house) of your life. Take care of it and it'll last a long time.
Double(. Y .)Dee
SSG, TXARNG
How To Use The FTC Gallery
VIN Decoder
Big 3 Upgrade
Seat Removal
Interior Trim/Carpet Removal
Old May 11th, 2012, 09:54 PM
Images: 616
Liked 167 Times in 149 Posts
good photos
one day I'll figuer out how to do them arrows and circles
dgg80970@gmail.com , DoubleDee , JSoko , Kap , Russo2
How to replace a Door Handle on a 1987-1996 Bronce & F150-F350 JSoko Garage Talk: Shop Class 101 4 March 18th, 2012 10:40 AM
'99-'08 F150 Air Filter Removal JSoko Garage Talk: Shop Class 101 0 July 7th, 2011 12:48 AM
Oil filter info and filter wrenches JSoko Garage Talk: Paint & Detailing 28 May 22nd, 2011 11:11 PM
Replacing Fuel Filter DIXIE FIX Garage Talk: Shop Class 101 4 April 19th, 2011 07:18 AM
Changed fuel filter - 95 F150 nine5flareside 1992-1996 Ford F150
28 August 24th, 2009 07:15 PM
0408 , 2004 , 2005 , 2006 , 2007 , 2008 , f150 , filter , fuel , fuel filter , replace
