Quantcast Basic 351w Clean and Paint - Ford Truck Club Forum
Old May 15th, 2012, 09:41 PM
Default Basic 351w Clean and Paint
So I thought I'd create this thread so I have a place to post pics and show what I did to the 351w in my Bronco when I go to "Clean" it. I'll list P/N's and price's for the parts I plan on buying
The plans are so far, to replace the Oil Pan Gasket(what it's being pulled for), Timing Chain and Gears, Temp Sender, Oil Pressure Sender, Paint(Ford Blue), Probably replace the Valve Cover Gaskets, new Intake Water Neck, maybe a new Water Pump. I'll kick around ideas here in this thread, but I WILL NOT be rebuilding it, just "Cleaning" it and Replacing a few parts.
I'll post the P/N's when I compile my list of what I need.
Old May 15th, 2012, 11:33 PM
Ridgerunner's Avatar
Images: 60
Liked 4 Times in 4 Posts
Subscribed
1998 Expedition 5.4, 194 led light bulbs for the running boards.
Old May 16th, 2012, 08:08 AM
are this things the engine needs or do you just feel like doing
Old May 16th, 2012, 08:10 AM
add a new cam & lifter kit
Summit Racing SUM-K4400 - $109.00
if I had it down enough to replace the chain the above would be a no brainer
but there again where do you stop the list could go on & on as is what happens to me
Old May 16th, 2012, 09:52 AM
I figure I'd replace the chain and gears because of how many miles are on the engine, as far as the cam and such, that can wait til I decide to really rebuild it.
Old May 16th, 2012, 12:57 PM
Images: 60
I always had good luck with a Cloyes timing gear set. Get one made before 1971. They will try to sell you one for a later engine. So you can say 1970 Mustang or something like that.
Old May 20th, 2012, 02:04 PM
First thing I'm going to buy is a new bolt kit for the oil pan, the old bolts will be coming out in favor of these:
http://www.ebay.com/itm/Engine-Oil-P...d3a6d0&vxp=mtr
JBG wants $10+$9.59 to ship they're bolt kit to my house. These are $13.99 with free shipping .
Old May 20th, 2012, 03:01 PM
Images: 60
Blue sounds like you are just fixing the stuff that is wrong which is ok. There is a bit more to do if you are refreshing a engine and a lot more work. For example checking the bearings for the crankshaft and con rods, pulling the heads off and checking piston bore to see if you can put fresh rings on the piston, Like J also suggested a new cam and lifter set, along with all new gaskets to put it back together with.
I would only do that to a engine with 50,000 miles or better. At 100,000 I would rebuild it and take no chances. You are on the right track with pulling the engine and doing repair work and prevented maintenance.
Also while you have your engine out it would be a good idea to replace the front transmission pump seal,so you won't have to go back and pull the trans to replace it.
Old May 20th, 2012, 03:09 PM
Like I said, no sense throwing a buttload of money I don't have at it right now, once it goes out, I'll pull it back out and either rebuild it then, or pull all the new parts off, buy a 300 and put it in. This is just to fix the oil pan and maybe give it a few more thousand miles.
Old May 20th, 2012, 03:13 PM
Images: 60
Just remember the seal for the front pump on the trans. So you won't have any surprise leaks.
(View-All Members who have read this thread : 35
2Customs , 88dually , ASwaff400 , barrett_s , BigBlue79 , BigRob , bikertrash3531 , Booba5185 , Burton7.3 , Counterfit Cash , Dave8N in Pa , DIXIE FIX , duke daddy , F150GT , FlaresideFan94 , Flatbedmark , fullthrottle95 , Hemifish , HiRoller , IrishKRO , JSoko , Matthew , michaelsnodgrass18 , Moore1991bronco , mrpontiac66 , Mtgoat , nflfreak43 , nine5flareside , Red91 , Ridgerunner , Russo2 , sbellinghausen , The Frankster , tmace , windigowolf
Rusty in Basic Training JSoko General Discussion
176 August 29th, 2018 10:13 AM
Need a water inlet for a 351w BigBlue79 Auto Parts Wanted
2 March 28th, 2012 06:58 AM
New Army Basic Training jallen3521 General Discussion
1 August 18th, 2010 07:15 PM
Here Are Some Basic Audio Terms - Defined SoundScape Garage Talk: Shop Class 101 1 November 28th, 2009 12:07 PM
351w , basic , clean , paint , refreshen
