Quantcast How to Replace a Broken Wheel Stud - Ford Truck Club Forum
Old July 18th, 2012, 04:30 AM
Images: 616
Liked 169 Times in 151 Posts
Thumbs up How to Replace a Broken Wheel Stud
Replacing a broken wheel stud is not as hard as it looks
Tightening lug nuts without a torque wrench can be a recipe for disaster. If worse comes to worse and you break the wheel stud, here's how to replace it.
If you’re just like everyone else, you’ve tightened the lug nuts on your car without using a torque wrench. You’re an “all the muscle you can put into it” kind of guy, and now you’re staring at a broken wheel stud. You can fix this yourself in about an hour and for less than $50. You’ll need to buy a tie rod end remover (OTC No. 7315A, at tooldiscounter.com), or rent one from an auto parts store. Then buy a new stud and two new lug nuts (yes, two of them). Next, stop at the hardware store and get a handful of washers with a hole diameter slightly larger than the threaded portion of the stud.
Above all, don’t hammer out the broken stud. That’s the worst thing you can do! The hammer blows can wreck your wheel bearings and turn this into a much bigger repair bill. Instead, squeeze the broken stud out with the remover tool. It’s staked into the hub, so the tough part is getting it to budge. Once it moves, the rest is easy. Rotate the hub until you find a deep recess so you can angle the stud into the hole. Then pull it through. Next, place a bunch of washers over the stud and spin on the lug nut. Crank down on the lug nut to pull the staked portion of the new stud into the hub.
Replacement procedure
1. Pull the broken wheel stud
I use a tie rod end remover
Place the remover around the head of the broken wheel stud, and behind the hub. Center the driving screw over the stud and tighten it with a ratchet until the stud pops out the back.
2. Pull in the new wheel stud
Stop tightening when the head of the wheel stud sits flush with the back of the hub. Install the second lug nut (the one you didn't toss) on the new stud—it'll go on easier. Tighten with a torque wrench.
By this point, you’ve probably stretched the threads or damaged the bevel. So toss the nut (they’re cheap). If you can’t fit the new stud into the hub, you may have to remove the brake dust shield (drill out the rivets and replace them with stainless steel screws, nuts and thread-locking adhesive).
BigBlue79 , BigT67 , Flatbedmark , gizmo06360 , JSoko , polargeek , Russo2
The broken lawn mower BigT67 General Discussion
2 July 26th, 2012 08:44 AM
How to Replace a Thermostat JSoko Garage Talk: Shop Class 101 0 December 15th, 2011 08:23 PM
Ford Broken Spark Plug Removal Tool JSoko Garage Talk: The Tool Depot™ 4 October 24th, 2011 11:54 PM
How to Diagnose and Repair a Broken Auto Light Socket JSoko Garage Talk: Shop Class 101 0 May 28th, 2011 10:24 AM
Replace brakes JSoko Garage Talk: Brakes & Suspension 0 December 16th, 2009 09:06 AM
broken , replace , stud , wheel
